Front fog light full of water.
Hey folks. Looking for a little tech assist here.
I noticed today that the driver side front fog lamp is half full of water. I'd a kind like to get it out, or replace it before it causes a problem.
I wouldn't be able to get it to the dealer until the end of the week at earliest, so I need to take care of it before the water freezes inside of the assembly.
I found an exploded parts diagram for an aero kit install that sort of details them. I also searched the forum and two methods to change bulbs came up.
1. Remove the lower front section.
2. Get at it through them the wheel wells.
If anyone has replaced the OEM fog lights, I'd really appreciate any insight as to the best method to remove the assembly.
I have a garage full of tools, floor jacks, and stands, so getting everything apart is doable for me.
Thanks in Advance
Mike
Thanks in Advance
Mike
Mike
Ditto.Just have the dealership replace the fog light under warranty and don't tamper with it.
I have a similar problem, my fog light lens has a hole in it probably caused by a rock, so it gets moisture in there and it causes the bulb to go out, I've had it replaced once. I want to replace the lens so this doesn't happen, but all I can find is the entire fog light assembly. Anyone know if I can just buy the lens somewhere?
And if so, is it something I couldn't do myself pretty easily?
I wouldn't mess with it either. Just leave them off and if the freeze does more damage to the case it really does not matter.
My dealer replaced the RF foglamp on my wifes MCS today because of moisture in the case.
There was a touch in the left but they elected to not replace it yet. I'm going to keep an eye on it and if it gets worse back the car goes.
Regards,
Pat
Regards,
Pat
Super easy, just took one out myself. Jack up the car, Take off the wheels. There are inserts (which hold in the inner fender lining) that have what appears to be a phillips head notch in the face. You will see they are 2 pieces. Put a tiny screw driver in the little rectangular notch which seperates the 2 pieces. Just lightly lever up on the inner section, then use a phillips head screw driver to unscrew the center section. So to repeat, there is an outer ring and then an insert that makes the outer ring expand into the hold. You have about 5-6 of these inserts, There is a small phillips head screw at the very bottom under the front of the bumper and one other that I can't remember where it was but if seen quite easily. Once these plugs are removed along with the 2 screws you can move the inner liner away (you only need to remove the screws and plugs in the front section of the liner) you can get at the fog lamp, Three hex head screws hold it in. I bought one on ebay. Make sure you get the one with the white adjustment wheel for alignment (if US cars have this) as there are quite a few non BMW ones for sale on the bay both here and in the UK. The new ones don't come with a bulb. I would clean your bulb with alcohol to prevent hot spots before reinstalling (it is a push in affair)
email me with any questions. pmustang(at)gmail(dot)com
where did you find it online? and does anyone have like a good "how to" on how to replace. mine is cracked as well, gosh these things need to be more robust! (or i need to stop driving so fast! ) ill go with the former
07-16-2020 12:54 PM
08-07-2015 05:55 AM
