MINI not run for a month
Don't put a trickle charger on unless it is one that will shut off when the battery has a full charge. Otherwise you risk over charging your battery. At best it will boil the fluid out of the battery at worst it will burn your car down.
A battery tender that has a float mode is what you need. For the length of time you will be gone I would not worry about the battery. Pull the negative cable if you'd like.
That's a very short period of time on a pretty new car. There shouldn't be any reason that you should worry about anything, seals or otherwise. A month sitting shouldn't drain your battery, either, even in the bitter cold, unless the battery is getting close to dead already.
Rest easy.
Rest easy.
That's a very short period of time on a pretty new car. There shouldn't be any reason that you should worry about anything, seals or otherwise. A month sitting shouldn't drain your battery, either, even in the bitter cold, unless the batter is getting close to dead already.
Rest easy.
Rest easy.
Regards,
Pat
Mini'mon
08-16-2015 04:15 PM
