Fuel filter tank seals were wrong!
#51
There is nothing wrong with the kits. ALL the MINI fuel filter kits have these seals that say diesel on them, but they fit and work fine. We've even tried to order different fuel filter kits and no matter what they all come with the seals saying diesel on them. So don't worry use em and they will work.
We keep Fuel filter kits in stock
http://waymotorworks.com/fuel-filter...0-r53-r52.html
Also good trick is to install it on the tank, then put the unit back in.
#52
IQ - thanks for the purchase of the fuel filter kit. They work for the Gen 1 R50 R52 R53 US MINIs. Fits good and seats. Looks like on some of the MINI One 1.6 and MINI One 1.4i.
They most likely shared the gasket parts of the kit with other diesel models or makes.
Fuel Filter Kit
http://www.ecstuning.com/Search/SiteSearch/16146757196/ES37416/
Fuel Filter Kit
#54
You will be fine. Just get the Genuine MINI kit
#55
Is there a definitive answer to the question of whether the Diesel Only seal is useable?
I replaced mine a couple of years ago twice as there was a problem the first time through. When I looked at the stored seals I didn't use, they say Diesel Only. Do I need new seals as I'm guessing that the ones in the car say the same thing.
#56
Yes, its fine and comes in the factory MINI kit.
#57
#58
You will be ok.
PhoR53
05-30-2022 10:37 PM
Lex2008
08-16-2015 08:33 PM
bc219
08-10-2015 11:22 AM
