Boost down 6 PSI since dealer repairs
on
Hey everyone,
a few weeks ago, i took my 2007 Cooper S in to have the alarm repaired and they ended up needed to reset the ECU, and ever since i picked it up my boost pressure dropped from 17 max (with overboost) to 11 Psi max with overboost. Was there a mistake made at the dealer in the ECU or is this some special winter program mix or something? I have noticed reduced performance as a result (obviously ), Should i the dealer up?
on
on
Scott 48
Did you get any answer on RPM at stop.
My O9 JCW goes to low (400 to 500) then high (1000 to 1200) then to Idle.
This happens more the harder the stop- or faster the stop.
At first i thought this could be SMOG management?
This is not that bad, and car runs good, but is not right.
Performance reduction after reflash
I had my car reflashed to activate rear fogs and have noticed a reduction in performance also. When I took the car (build Oct 07) in and they said they had to reflash the ECU I asked if the new program would change performance. They said it would, but they could only activate the fogs with a reflash. Have to have rear fogs in England so I had to accept the loss.
you already have the "reduced performance". Or more better way - you missed out on the 07 extra boost which most 07s will lose as they get reflashed.
Are you sure the scangauge is displaying boost ? in this thread it seems that out of the box, the scangauge is displaying MAP (manifold absolute pressure) to which you have to deduct the atmospheric pressure at your altitude to obtain the real boost from the turbo.
My stage 1 JCW highest boost on scangauge is 29.5 psig which equates to 14.8 psig at sea level.
07-16-2020 12:54 PM
Indimanic
08-19-2015 11:08 AM
