Battery tender question
I recently purchased a Battery Tender charger with a cigarrete adaptor. Has anyone used this attachment? In order for the charger to begin charging I have to turn the key to position 1. When I do this the speedometer and tach lights are on. Is it O.K. to leave the key in position 1 for say three to four hours while the battery is charging? I can of course use the alligator clips attached directly to the battery but the battery cover on a Cooper can be a problem removing. The plastic clips break quite easily especially in cold weather. Any help would be apprecaited.
Ken
Ken
Additionally, how long do you plan to not use the car? A friend of mine pretty much leaves his MCS in the garage from Oct thru April... and has done so since '03... never had a problem with the battery (still original). This doesn't seem to be as much of an issue with the MINI as it can be with other cars... like my '78 Spit 6... which seems to drain the battery despite having a neg-terminal disconnect...
Did it come with quick disconnect option? (two ring connectors attach to the batter with a connector to the tender) I use that on my Miata.
You'd probably have to cut a notch in the battery cover to let the pigtail hang out, but I'd prefer that to leaving the car in accessory mode for hours on end...
By the way, the Battery Tender works great on my 80 Spitfire. No worries having access to the battery on a Spitfire!
stevepsd
35
12-06-2022 04:22 PM
MiteyF
08-26-2015 06:07 PM
Getrieben
08-15-2015 10:09 PM
