Why I won't buy a MINI - yet
#126
Ah, this might have something to do with the 1st gen cars being 3-7 years old vs. 1-2 years old for the 2nd gen. And that there are probably 2x or 3x more people on here with 1st gen cars vs. 2nd gen cars.If you're going to use a statistical measure to make a conclusion, you've got to normalize the data!- Mark
I never claimed perfection or data completeness, it was simply an observation as to the comparative number of posts. However, if U trace Consumer Reports reliability data from 2002 to 2008, you WILL see an incremental improvement from 1st gen to 2nd gen, to the point that one issue last spring had the MINI Cooper in lofty territory with only 2 other cars that carried solid red dots across the board for reliability, resale value, and customer satisfaction, the Prius and Fit, for the first time ever.
So while I never claimed my data was perfect, the 2nd gen car is more reliable, better built, and less quirky than the first gen,while the product, as a whole, has steadily impoved since 2002. I see this in my current car, when compared to my previous, and any SA across America will tell you this: while some issues persist, there are much fewer warranty chargebacks now because BMW has worked hard to improve the product
Let's see, 1st gen: the entire problematic steering system, inc pumps, racks, fans; drivetrain (clutches and flywheels, CVT, axle housings/CV joints), engine mount leaks, door sill rust, spontaeneous combustion (see steering), persistent engine stumble, bonnet and hatch latching issues, leaking coolant tanks, electrical gremlins, wobbly headlights (see bonnet latching) windshield stress cracks, loud dash rattles (to the point that they had to go from 5 to 3 piece after 04), failed fuel pumps, mushrooming strut towers, warped moonroof cassettes, the usual BMW window issues, door latch cables, cabrio soft tops premature wear-thru, etc etc the list could go on...
2nd gen: hood scoop warp, the so-called cold start rattle, clutches/flywheels, fuel line freezups (Heet, anyone? ), moonroof problems, the usual BMW window issues, occasional TPMS sensor problems, and leg burns from tailpipes are the only major repeat issues Ive read about...
If anyone can add to either please do so.
#127
As any computer troubleshooter of software issues. Lots of times it's the interaction of many factors and interplay that may cause the issue. ... Most troubleshooting at the dealer level is not very well done these days. Sorry if this offends anyone but most modern "Mechanics" are parts changers as this makes the dealerships more money. ...the manufacturer can't reproduce it without the car in question which I doubt they rarely see!!!
Cheers!
#128
I dont have access to the latest CR data, but up until a year or so ago, it showed generally average reliabilty across the board except for the problematic first couple of years with no significant change between the Gen1 and Gen2 cars. If you've got more detailed data, I'd like to see it.
- Mark
#129
I only have read the first page and last ... but going by your user name you should be comfortable with the MINI HT or CM and dealing with special cars....You have or had a Lotus?
Lots Of Trouble Usually Serious............. I had an exigeS.
If you like the MINI go and get one...is a fantastic little car.
#131
LotusLight
I do not see the Mini in your future either but hope that when you feel more comfortable, you will jump in and also join our forum. Perhaps we can see you on the track some time soon as well.
Good luck with your car decision. I am glad you are well informed.
#132
LotusLight
#133
Thanks! Track days would be fun. My convertible Lotus does not have a roll bar, so track days are out of the question at present. Even with a roll bar, my head sticks well above where any roll bar would be, so track days might not be a good idea anyway. That would be one of the neat things about a Mini -track days! I could take a Dodge Viper! In the meantime, the street has no rules about roll bars - just obstacles like slow moving cars and speed traps. Yikes!
Which Lotus do you have? Is it the Elise or Exige?
I ran track with a 2005 Elise for 1 1/2 years a while ago. Many HPDE outfits would not let you run w/o the hardtop. Easy car to drive fast but a tough car to master on the track. It does not like large slip angles but rewards TBO and TTO when it is done well. Initially, I would not try to take too much HP or racing tires to the track. You would be able to learn a lot more with a "stock" momentum car like the Mini or the Lotus. I have seen, under expert professional driving, what the Lotus Elise can do and am impressed.
Good luck to you. The Mini is really a fun car. And it is easy to get in and out of it.
#134
LotusLight,
#136
I keep an eye on both the 1st & 2nd gen forums here on NAM, and the one thing that I can say that is pretty consistent is that the 'Stock Problems/Issues' section on the 2nd gen is a good deal shorter on a daily basis than the 1st gen equivalent forum. Not to say that there is a comparison to the two as far as problems go, but the 2nd gen forum is fairly small, with around 15-30 posts a day, usually focusing around the same things that seem to be issues with the second gen car, i.e. sunroof, cold-start rattle, hood scoop, etc.
#137
Somebody posted a video taken from a Lotus which overtook a Mini on a track (cool video with all the stats - speed, rpm, etc). Watching it, my first thought was why was the Lotus going so slow. So, I watched it again and the Lotus did something like 10 seconds faster on the second lap. He was just warming up. No knock on the Mini, but Lotus has won an Indy 500 and the Elise is almost 1000 pounds lighter with more HP than the turbo Mini.
Did the Lotus Elise win the Indy 500? No. Then how can you compare that either? Using that logic, the Isuzu Impulse won the Indy 500 too because the suspension is Lotus designed.
#138
You can buy 2 base Cooper S Turbo cars for the price of 1 base Elise. How can you even compare the two?
Seriously, who compared? I was just replying to a poster and commenting on a video which had a Lotus and Mini. My Indy reference was not clear: I meant that it was no sin for a Lotus to overtake a Mini on a track. Lotus has a long racing heritage, including an Indy 500 win and their cars clearly have that racing heritage designed in.
The current Lotuses are entirely different than a Mini and not a substitute. What they have in common is being zippy, nimble and fun to drive. Of course, I also remember a Honda 50cc minibike that was a lot of fun to drive too.
#139
You have to go to the right person. See Jessica Confessore next time you hit the showroom. She is the best MINI salesperson they have. I'll be happy to let you have my name so she'll take good care of you
Clubman
Glad to hear Lauderdale Mini service is good, because that is the dealership I have been visiting. I have been completely underwhelmed with the sales staff's knowledge of the cars and the options (at their BMW and Mini dealers), which is why I have hit these forums. I test drove the Clubman JCW they had out front and liked it a bunch. They didn't offer me enough for my trade (which I don't blame them for, it is the market) so I couldn't do anything with them at the time. Still have to sell my Box. The other car I am seriously considering is in the price range and will be a lot of fun to drive as well, and comes with its own list of quirks and dealer/warranty issues.
#141
i'm a new owner of a new MINI. wanted it badly since it first came out and had to hold off getting it for a number of reasons until recently. i absolutely love my car. the bliss i have owning it now made the wait well worth it. i'm the kind of MINI owner who waves, flashes a shaka or holds up a peace sign if another MINI approaches and there's a chance the owner can see me.
coming from that perspective--and perhaps this is dismissive--but to me, a nonchalant/dispassionate/dismissive potential MINI buyer shouldn't become a MINI owner. taking it further--and i'm very much for free speech (and note that right actually applies when it comes to government censorship)--it seems inane to me that someone would start a thread soliciting opinions on why you wouldn't buy a product on said product's forum. the OP might claim that it's mainly out of curiousity, and that might be so, but to this reader and lover of her MINI, that curiousity is laced with venom.
in my opinion, someone who takes the time to attempt collecting anti-MINI-purchasing opinions on a MINI board, and then write lengthy posts to chide those of us who tell said poster to buy something vanilla like a toyota is playing a passive-aggressive game of faux superiority.
but what do i know? maybe i'm not as discerning an auto buyer as someone who owns a lotus. *shrug*
#142
#143
#145
Posters often say the forums are not representative, too small a sample size, etc. Very true, but we all have to make decisions on the information we can obtain. Info is NEVER perfect, even with statistical samples. The key is applying the information you can obtain and using judgment. My judgment may be different than yours using the same information.
Another common theme has been that all cars have problems, nothing is perfect. True. And while you are playing the lottery when you buy any car to a degree, when you go to Vegas you probably don't seek out the worst bet do you? The facts are there are some serious issues that have arisen with some (unknown) number of Minis and in Peugots using the same engine. As important if not more so, is that Mini and Peugot to date has been unable to diagnose and resolve the problems, even though they have been working on it for some time. Most folks who have the engine problems are pretty distressed about it. Why not wait for some resolution? What is 6 to 12 to 18 months in the scheme of things?
...though I did experience how easy it would be to "drink the Koolaid" this past weekend when I had the chance to check out a new R57 S at a Chicago dealership. The temptation was intense. Of course, when the MA claimed total ignorance of the melting hood scoop and cold start death rattle issues with the Peugeot engine, it brought me back to reality.
Even if unavowed, there is clear evidence from multiple sources that BMW MINI has acknowledged the existence of these issues and is working behind the scenes to understand and rectify them. Were I in the market for a new R55, R56, or R57 I would agree that a prudent and reasonable course of action would be to wait for a few months and see how it all plays out. Doesn't make me any less of a MINI lover.
#146
but again, that's me and my personal opinion. you posted your viewpoints on here for others to weigh in on; i've posted mine in opposition. that's the whole point of a discussion board, regardless of whether i think your POV is lamely passive-aggressive, or whether we were in complete agreement.
that said, aloha, dear gents. what can i say? i got mine. i'm sure you're enjoying yours, if you have one. if you have a lotus (or other car) instead, have fun with that one. if you're considering purchasing a MINI, i say go for it wholeheartedly. but if it's not for you, well--even a vanilla toyota camry has its faults and its bennies.
#147
Looks like anyone who endured any sort of Lotus ownership (including Toyota Elise), shouldn't be afraid of owning a MINI in the 3rd year of the redesign run.
It will be a long time before I get the courage to dive into hand-built car ownership again. Maybe when I'm retired and have a ton of spare time / cash - then I'll do this again, but I'm glad that I did my Lotus stint in my barely thirties without breaking the bank. Now time to play with something that's almost as much fun, yet has 50K worth of warranty :P
#148
logically speaking, my one (now two) posts hardly count as ranting when compared to LL's many posts lengthily & repetitively belaboring the few points about why he won't buy a MINI..."yet" or otherwise. i mean, come on! it's up to you either to pull the trigger or not. personally speaking, such public waffling over what are to me, statistically unimportant or minor, practically speaking, when the car as a whole is so awesome, is rather pathetic.
In principle, I do agree with you that how careful or cavalier you approach the purchase of a new MINI, no matter how much you love them, is a personal thing. At the same time, I would say that everyone is also fully in their own right to determine for themselves whether known problems with the car are statistically unimportant or minor based on the available facts and how thoroughly they do their research. You and others don't seem to think they are significant. Others, including the OP, believe they are at least significant enough to be patient and see how BMW MINI's publicly stated mitigating actions play out. No harm in people expressing their different points of view.
Actually, I just recently took the time to read all the way through Twin Turbo's "Yellow Engine Light" thread. Even if NAM only represents less than one percent of R55/R56 owners, there's still a whole lot of unhappy people with their new MINIs. N/A to you living in HI, but being from a cold winter geographic region it moves me even more into the OP's camp.
#149
my reasons were completely different from yours--i had no qualms about the product whatsoever. ...................[edit]..................................
Y'all have fun, and howdy from Texas devlynaskurt!
#150
Sequence - I saw that your Mini has joined the ranks of those with the startup clatter. I am sorry to hear that and wish you luck. I do think it will be resolved, hopefully sooner rather than later. Keep watching Southpark!
