Rear caliper pistons rotate but dont compress??
Trying to do the rear brakes here, but I've run into a bit of a snafu... In lieu of spending $60-70 for a compression tool (yes I know HF is cheaper but I can't wait all week for it to ship), I've been using the needle-nose plier technique. The piston is spinning free and easy so I know it's not seized, but the damn thing won't move a micro-meter backwards! I've even got the bleeder open to relieve back-pressure, but no result. I was thinking I would just cut my losses and take the whole caliper off the car entirely so I could get a better angle on it, but I can't figure out for the life of me how to get the e-brake cable off the car!
Any hints?
Any hints?
Next time use a c-clamp in combination with the needle nose pliers and you'll be golden. That said, most of the time I can just push axially on the needle nose pliers to "thread" the piston back into the caliper...and I'm no bodybuilder.
Good to hear you got it figured out. That "threading" is necessary for the e-brake to self adjust as he pads wear down.
No. That tool just compresses the piston so you can get new (thicker) pads into the calipers.
Instead, something like this set. I have a smaller set from HF but do not see it on their website.
http://www.harborfreight.com/18-piec...kit-69053.html
07-16-2020 12:54 PM
squawSkiBum
10-02-2015 09:21 AM
brother i
Tires, Wheels, & Brakes
08-23-2015 01:15 PM
