Dome light keeps flashing while driving... why?
It only flashes while driving and it slowly brightens up & then slowly dims out like some kind of warning. It seems like maybe it does it after shifting gears but I'm not 100% on that.
Stop playing Disco on your stereo! Seriously though, I would suspect a faulty door switch.
One question on the convertible version? does it have the same 3 position switch as on the HT model? OFF, DOOR (on when doors opened) and ON. If in the OFF position does this still happen? or only on DOOR? or flicker if ON when driving? As others have stated, check the door latch switch, but in the OFF position should not matter what the DOOR switch does! It should just be OFF, unless the switch is different?
Hope you're able to find it easily, and it's just the door switch. There is electrical contact cleaner that may help it if it is this....GOOD LUCK!!!! let us know.
Regards
Scott.
Regards
Scott.
Regards
Scott.
Regards
Scott.
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
01-30-2021 02:35 AM
07-16-2020 01:54 PM
12-23-2015 11:36 AM
