Key failure
Key failure
Hi Everyone,
I purchased my mini six months ago (used) and read that I need to rotate keys so the key battery stays charged. Which I did once a week but a couple of months ago one key stopped working and now the other one once in a while I have to get really close or press it more than one.
Question, can the battery be chaged or do I need to buy a new key(s)? It doesn't look like the key comes apart.
Thank you,
TonyG
![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
Thank you,
TonyG
I was told that too. I'm just a skeptic I guess, if it's rechargeable in theory it should last longer, right now the key fob in my mom's 02 Cavalier seems to have better battery performance :D
Maybe this is like the "speed-sensitive volume" control that the H/K head-unit has, the features in the owners manual, but not real.
The '05-'08 (R53 Hardtop and 1st gen R52 convertibles) are BMW keys that recharge automatically in the ignition and there are no user replaceable batteries in those.
For the second gen MINI (2007, 2008, 2009 R56, R55 (Clubman) and R57 (Cabrio) the keyfobs also recharge automatically in the ignition slot. HOWEVER.... AND VERY IMPORTANT.... if your R56, R55 or R57 was ordered with the keyless "Convenience Entry" $500 option, then your keyfob requires the use of a standard lithium battery and it will not recharge in the ignition slot.
![Wink](https://www.northamericanmotoring.com/forums/images/smilies/wink.gif)
You won't need to worry about that, as long as the car sees a signal from the chip inside the fob, the car will still start, but you will have to put the key in it's slot. And of course your comfort access won't work.
As for the range deteriorating on the newer style key fobs, it can be attributed to the loss of initializations. If you reinitialize your keys it should increase the range a little bit.
1) Close all doors
2) put the key in the ignition, turn it to position 2(key on engine off)
3) remove the key from the ignition press and hold the unlock button
4) while holding unlock, press the lock button three times, then your doors will lock and unlock.
5) If you have a second key, repeat step 4 with that key after the 1st key has been initialized.
This will also help if the remote isn't working. Unless there is some other problem that's not the key or battery.
I have a key fob question..
Has anyone had this problem? I drove some where and then park the car , shut off the engine and the key fob wouldn't release and come out of the holder... Then I decided to restart the car and it wouldn't start..I called the dealer service dept. He said to call min road service..
I decided to try it on more time and the car started.I shut it off and the key fob released from the pad..
Key Fob
Thanks... That may have been it.. We have a automatic because of my wife back problem she might have trouble shifting.. I don't remember if I still had it was in drive or not.. That sure is a possibility..I'll keep a eye on it..I have had some trouble just trying to insert the key fob.. So with that issue compounded with the new problem of it not releasing the fob or even starting. It was some what unnerving for a 09..
newminijcw
10-21-2015 02:37 PM
