Door Issues
on
Door Issues
I've got an 04 MCS and I have been having problems with my doors not unlocking. The driver door will occasionally lock me out when I close the door. The little manual lock comes half way out of the door, but will unlock with the button on the key. The passenger door does the same thing and to open the door you have to manually pull the stick on the door to unlock it. Could this be the lock actuator or is it the cable inside the door? I want to fix this myself... I have heard that the dealer can fix the door so you can simply pull the handle once, unlocking and opening the door at the same time. Is this something that I can do?
on
Is the passenger door unlocking when you hit the toggle switch?
Both doors exact same problem? If so, unlikely to be a mechanical problem. If electrical, best to take it back to dealer.
07-16-2020 12:54 PM
xpunisherx
09-01-2015 11:47 AM
