Issue w/indicator lights
Old 03-21-2009 | 11:43 PM
BritieTheMini's Avatar
BritieTheMini
Removed
Old 03-21-2009 | 11:57 PM
ScottRiqui's Avatar
ScottRiqui
The combination of ABS, ASC,DSC, and TPMS lights is the classic symptom of a bad wheel speed sensor. My wife had the same thing happen with her car, but I don't remember if she got the "service engine soon" light as well. I think a bad steering angle sensor can also give similar symptoms.
I don't know how mechanically-inclined you are, but since the wheel speed sensors are exposed to the elements, they're often just dirty rather than failed. You might be able to remove, clean and reinstall them to clear up your problem. If one or more *are* bad, you could do the replacement yourself for much less than the dealer would charge.
Old 03-22-2009 | 12:13 AM
Oxybluecoop's Avatar
Oxybluecoop
When you get a chance stop by your local Autozone store and they will plug up a code reader(at no charge) to your MINI and tell you what the problem is according to your MINI's ECU.
Old 03-22-2009 | 07:42 AM
zminitech's Avatar
zminitech
Sounds to be a bad wheel speed sensor, my bet is the left front, as for the CEL, do you have an automatic transmission? If so, the wheel speed sensor is also causing a fault to be thrown for the trans and will set off a CEL.
Old 03-22-2009 | 08:09 AM
BritieTheMini
Removed
Old 03-22-2009 | 08:28 AM
lhoboy's Avatar
lhoboy
+3 or 4 on the wheel speed sensor.
Old 03-22-2009 | 08:40 AM
BritieTheMini
Removed
Old 03-22-2009 | 08:43 AM
lhoboy's Avatar
lhoboy
+3 or 4 = agreeing with 3 or 4 others also pointing to the wheel sensors.
Old 03-22-2009 | 01:00 PM
BritieTheMini
Removed
Old 03-22-2009 | 01:14 PM
miniola's Avatar
miniola
Originally Posted by BritieTheMini
Unfortunately the problem is reoccuring. It was taken out for a drive and all the lights from the three indicators to the service engine soon lights came on and remain lit. My father thinks it could possibly be from one of the sensors that isn't screwing on fully. The other three are, but one will not. Do you all think that might be the reason for the headache? Also, we obtained records of the maintenance the original owner had performed when taken to the dealer and three or four times it says something about the tire indicator light. I am not sure if this is due to the actual tire indicator that needed to be reinitialized and she just didn't know how to reinitialize it or if it is something more like what we are experiencing. Any suggestions?
No loss of power or rough idling, right?
Old 03-22-2009 | 01:26 PM
BritieTheMini
Sick car
Removed
Old 03-22-2009 | 04:13 PM
lhoboy's Avatar
lhoboy
It still sounds like a bad wheel speed sensor (it's not really a tire pressure sensor like the ones on the Gen2 cars).
Old 03-22-2009 | 04:34 PM
BritieTheMini
Removed
Old 03-22-2009 | 05:49 PM
lhoboy's Avatar
lhoboy
They should be able to pull the codes to determine why all the light were set off, even if the lights are off when you get back to the dealer.
Old 03-22-2009 | 05:56 PM
BritieTheMini
Eeek!
Removed
Old 03-24-2009 | 12:53 PM
BritieTheMini
Removed
Teh
06-13-2018 03:59 PM
Herleman
08-16-2015 07:41 PM
Colt45Magnus
08-12-2015 07:43 AM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 11:39 AM
quality_sound
08-07-2015 10:36 AM
