Fault p1476? Leakage diagnostic pump clamped tube?
Checking to see if there is any new wisdom on fault P1476 "Leakage diagnostic pump clamped tube".
I have an '05 Cooper S that just threw this code tonight. Of course it's two weeks after the warranty expired and the Bentley manual I ordered a couple weeks ago is on back order. Lovely.
I did a search, it seems this is fairly mysterious except for one poster who fixed a few of these but couldn't remember what the fix was
I'll reset the code tonight to see if it comes back, but it'd be great to know where this leak might be. Is it something to do with the evaporative system?
Thanks!
-Rob
Thanks!
-Rob
If it comes back, i'll take a look at the hoses and let you know what it ends up being.
Thanks,
-Rob
The pump itself is called a Leak Diagnostic Pump (LDP), “clamped” refers to blocked; however, according the techs I’ve surveyed, the issue is within the pump the majority of the time. The standard procedure is to clear the code, if it returns, change the part (less than $100 from NAM discounter vendors). I found one instance of a person from a Google search that repaired the pump with success. MINI LDP failures are not numerous, but they’re not isolated occurrences either, the parts warranty person at the local dealership says he sends back three a day for BMWs and about that many a month from MINIs. Just as a note of curiosity, it is the only “assembled in Mexico” part I’ve seen on a MINI, I mean nothing disparaging about that observation.
Accessing the part for replacement is not difficult and the entire assembly is light, put the vehicle on stands, remove the right rear wheel and liner, pull the small tube at the top of the LDP, unscrew three 10mm nuts, lower the carbon canister and LDP assembly a few inches, disconnect the wire connector on the back side of the CC and upper quick releases for the upper vent tubes on the CC, once the assembly is out of the vehicle remove the remaining large tubes from the LDP, unscrew three T-25 screws securing the LDP. The LDP and assembly (5/03 MCS) I removed are configured differently than the one pictured on post#2.
-Rob
on
I finally got my hands on a Bentley manual... a note for everyone...the LDP and location changed after the R53 refresh.
The LDP is under the right rear wheel housing on 2002-2004 Mini's.
For those of us with the '05 and '06 model years it is located under the right rear side of the vehicle. The manual just says to remove "plastic underbody wind deflector at right rear corner", disconnect wiring harness, disconnect hoses and slide the LDP unit out. Looks different from the earlier model year.
If there's interest, I can take pictures when I take a look at mine ('05), although it will probably be another week or two.
-Rob
Yeah, mine came back after the next tank of gas.
-Rob
-Rob
The gas cap throws a different code (can't remember off the top of my head). A bad LDP doesn't hurt the car but it will cause you to fail an emissions test.
-Rob
09-02-2015 09:05 AM
