How to demonstrate Cold Start Chatter for dealer
#26
on
Film the event with a good digicam or similar unit as suggested earlier. Get a minute's worth of noise, maybe with the hood up for emphasis and then get a shot of something to insure that it's definitely your car doing it. You can burn that to disc so the dealer can see/hear it on a pc, not just on the little digicam screen.
I wouldnt record it from the outside, bonnet up-- with DI and cold valve lash these engines are way too noisy when cold otherwise, plus any ambient exterior noises will cloud the situation. Best to record the noise on the inside, glove box door down, windows up. that way it WILL be heard.
#27
OK, I spoke with both of the SAs at Braman MINI in Miami and had the tech look at it. The noise is normal and after the car warms up it goes away, as it does. IF it makes the noise when the engine is warm, then the replace the belt tensioner or soemthing like that and it fixes the problem. However, upon cold start and about for 1 or 2 miles, that noise will reappear and as soon as the car wrms up, the noise goes away.
So, per MINI/BMW if the noise is apparent when the car is warm, then fix. If it happens when the car is cold and then disappers when it warms up, no fix.
So there you go. They do have an alert listed for this problem but as I said, they will only fix it if it makes the noise even when the engine is warm.
#28
#29
I've read the BMW reference document on the timing chain issue - SIM-11-02-07. There is no requirement for the engine to be at operating temperature. Indeed, the problem occurs only after the car has sat for an extended time and the tensioner piston has collapsed. Remember last year when BMW's "solution" was to purge the piston's air by running the engine at 2000 rpm for 2 minutes and announcing "Problem solved!".
If the timing chain and rails have really suffered extensive wear due to excessive slack, the engine will be "noisy", but not the sharp clatter like a diesel. Mine certainly was. Got the new chain - much, much quieter even at operating temp.
#30
#32
on
better check yr owner's manual to see if 5W-40 is approved. yes BMW can test viscosity and if it's NOT in the approved range it could compromise yr warranty.
OTOH the range of approved oils expanded with the 09 models; for example 0W-30 is OK now, where it wasnt before. I run 5W-30 Castrol Syntec.
#33
Hmmmm, so what do we do? Do we just keep bringing it back and complain that it is doing it more often or occasionally when the engine is warm or what? I don't feel as if the engine is running any differently but what is the long term complication of this "hiccup" if any exist?
#34
Just to post my experience. I bought at Towson Mini in Maryland. I have experienced intermittent chain rattle upon startup. That is when you will hear it. I took the car in for 28k service and explained the issue. They replaced the tensioner and measured the chain travel with no further questions asked. Did not need to hear it happen, etc. I suspect that if you push the dealers, they will address the issue. I would certainly have it addressed.
John
John
#36
09R56
11-16-2022 10:49 AM
alistaircookie
10-08-2015 10:52 AM
