Brake squeaking?
Brake squeaking?
Hi folks. I had new brake pads (EBC Red Stuff) installed about 2 weeks ago. The car stops fine, but I've been hearing a squeaking sound coming from the rear left wheel. The frequency of the squeak varies with speed and it only occurs when I'm NOT braking--even the slightest pressure on the brake pedal will stop the noise. After braking, it takes a little time for the noise to return, but it always returns.
Does anybody how what the source of the squeak may be? Does bed-in noise occur when the brakes aren't being applied? Might it actually be a rear suspension component that squeaks only when under load (i.e. when I'm not slowing down)?
Thanks in advance for your advice!
Tinklespout
16
09-06-2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
09-03-2015 03:22 PM
