Need brake diagnosis please
Old 06-02-2009 | 10:20 AM
herbie hind's Avatar
herbie hind
have power bled brakes a few times and still crap . the pedal is initially firm and can be compressed a bit .but if i hold my foot on it i can get it to continue toward floor . so has anyone heard of mc seals wearing internally and not the usual (fluid on the floor) out the back?
Old 06-03-2009 | 01:01 AM
Eric_Rowland's Avatar
Eric_Rowland
Hmmm. If your foot is going to the floor, the fluid is going SOMEWHERE. If you do this a few times, do you notice the fluid level getting lower, or air bubbling into the master cylinder reservoir?
Old 06-03-2009 | 06:44 AM
herbie hind
that's what i was thinkin (WHERE's it goin) ? no fluid loss . but i did not look for bubbles . thx for the help . i'll try it .
Old 06-03-2009 | 07:01 AM
zrowcool's Avatar
zrowcool
take a look at the rubber brake lines also, i had a problem with the hydraulic clutch in my porsche where i would press the clutch pedal but the clutch wouldnt move, happened that one of the rubber lines would expand like a huge bubble when i pressed the pedal.
Old 06-03-2009 | 07:38 AM
Dr Obnxs's Avatar
Dr Obnxs
There have been a couple reports..
of seal failure where the fluid leaked from the master cylinder into the brake booster. It just gets sucked into the engine and burnt. I'd think that's what's happening to you.
Matt
Old 06-03-2009 | 08:09 AM
Bigshot's Avatar
Bigshot
Is the engine on or off when you do this?
Old 06-03-2009 | 10:48 AM
herbie hind
exactly . it's on but no loss of fluid . it doesnt drop to the floor and i havent let it go all the way to floor but can assume it would . my mother in laws altima does this and is new . hers has much more initial pressure though. it does take force but i've never seen a car 's pedal keep going - normal?
Old 06-03-2009 | 11:12 AM
MINIdave's Avatar
MINIdave
Sounds like the master cylinder is bypassing internally, the fluid is pushing past the internal seals but not past the external ones. You either need to rebuild that one or buy a new one.....
Old 06-03-2009 | 01:07 PM
herbie hind
let's say it got air in the abs unit , i may have let mc run too low on fluid when bleeding last yr. can this unit be bled ? i looked for bubbles and none . i did try to floor it and (good news ) it would not . it does pump up a bit better if i pump um a few times . is there a rebuild kit available for these mc's? and if air in abs am i f'd? thx for all replies .
Old 06-03-2009 | 01:24 PM
quikmni's Avatar
quikmni
I would suspect air in the ABS. I had this problem in my Camaro when I let all fluid drain out during a brake and line swap. I repeatedly pressure and pedal pump bled the brakes and then replaced the master cylinder but that did not help. I finally took it to a shop where they pressure bled five times. It was better but not great. The shop said they suspected a air bubble in the ABS which can be hard to get out. We pedal pump bled the brakes a few more times and finally got it back to normal.
Old 06-03-2009 | 03:13 PM
herbie hind
thx ; i guess i'm a brake bleeding fool for a while !!
Old 06-04-2009 | 08:07 AM
Bigshot's Avatar
Bigshot
This may not work on the MINI as I understand the ABS unit needs to be "cycled" by a piece of equipment the dealer has.
Old 06-04-2009 | 02:48 PM
herbie hind
dude.....
Old 06-04-2009 | 02:53 PM
BlimeyCabrio's Avatar
BlimeyCabrio
The Bentley manual states that the car needs to be connected to the dealer scan tool and the ABS put in a service mode for "proper" bleeding. That said, MANY folks have done full bleeds without this... but I know I let my reservoir run dry once, and suspect I have some air in there because I've been spongy ever since, after several flushes and bleeds... I may have to break down and pay for a dealer flush eventually.
I'm going to do one hardcore manual bleed with my son on the pedal and me on the bleeders, and see if that shakes loose whatever air is left in there... I usually use a Motive powerbleeder and that hasn't done it.
Old 06-04-2009 | 03:14 PM
Dr Obnxs's Avatar
Dr Obnxs
Not just the dealer
but many repair shops have the tools. FWIW, the AutoEnginuity SW with BMW extensionis can put the ABS system in "service mode" (actually it buzzes and clanks as it moves it's valves and pistons....)
Might want to take it out for a spin and get the ABS to engage (more than once) and do a bleed or two as well. Worth a try for sure.
Matt
Old 06-04-2009 | 03:17 PM
cristo's Avatar
cristo
Alliance Member
Matt
Pretty easy to do this on gravel, ice, or snow, somewhat easy in the rain
on smooth roads.
Old 06-04-2009 | 03:20 PM
BlimeyCabrio
Hmmmm..... this may be the thing that pushes me over the edge to buy AutoEngenuity...
Old 06-04-2009 | 03:48 PM
quikmni's Avatar
quikmni
On my 2003 MCS I let the reservoir run dry when I swapped my brakes. I filled the reservoir, bled the clutch, and bled the brakes. All was good, I guess I was lucky.
For some cars, I have read that the key has to be on, to activate the ABS, during the bleeding process. I do not know if that is a good process for the Mini but it might be worth investigating. I also like the thought of just getting the ABS to activate by driving and skidding. Then trying again to bleed the brakes.
Old 06-04-2009 | 09:49 PM
Dr Obnxs's Avatar
Dr Obnxs
I've got it...
And it's expensive for sure. I'm not that happy with it, the data logging is slow, but it's a lot less than the professional solutions....
Matt
Old 06-05-2009 | 05:07 AM
BlimeyCabrio
Yeah, I know it's not perfect - I've read the critiques here - but given how deep I'm getting into DIY on the MINI, and given that I have some weird behavior that I want to diagnose, and given that now there's this ABS thing... It's probably worth the money for me. I'll probably add another datalogger later along with some dedicated probes (wideband, EGT, other temps).
Best deal I found was at bimmerzone.com. Ordered.
Old 06-05-2009 | 11:13 AM
herbie hind
thx guys great idea to try and activate the abs then bleed . i will try it . now i gotta find some sand .....
Old 06-05-2009 | 11:41 AM
BlimeyCabrio
You can drive over to my house next weekend and we can use my AutoEnginuity....
Old 06-05-2009 | 12:44 PM
Cadenza's Avatar
Cadenza
On modern ABS units, the factory or compatible scan tool is required to bleed the ABS. You can also activate the ABS by locking up the brake and causing a skid a few times. A wet road surface helps. I've done this on my other cars.
Old 06-05-2009 | 06:41 PM
herbie hind
k wherwe you live?
Old 06-06-2009 | 07:53 AM
k_h_d's Avatar
k_h_d
Blimey,
So did you order the AutoEnginuity scan tool/software? I am intersted to see how you got on with the ABS activation with the tool and what the process involved.
