Car wont start.
on
Car wont start.
I went to start my car today and it didnt start, the lights would just flicker and there was a clicking noise. Also i opened the battery compartment and there was some water on the bottom of it. None above the carpet, just in the battery compartment. The battery is showing a green color which means its good. All my gauges reset also when i tried to start it.
Even the gas gauge would jump around then settle. Any ideas? I disconexcted the negative side and tryed again but nothing happened. Could this be the battery?
on
on
As for water leaks... I have seen the 3rd Brake light leak, Also have seen water come in from under the plastic clips that hold on the chrome trim at the bottom of rear glass. Also have seen water leak in from trunk handle srcrews, and the body vents under the rear bumper cover. If you have a sunroof the hose could be leaking but normally the headliner would also be wet too. I would pull the panel off the inside of the trunk and close it and have someone hose the trunk. Stay on the inside and grab a flash light and find the leak.
on
Im thinking it was the battery getting too hot. Because it rained again today and it was spotless in there. I charged the batter and it worked but i didnt leave anylights on and it just died. I guess i should replace it? Any reviews on Helix's lightweight battery? Thanks guys, i freaked out when i saw water in there.
09R56
11-16-2022 10:49 AM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
