A/C issue (bad smell)
hi,
Today I turn on my car in the morning and my a/c smell like cow *****&^ or something like that. After few minutes the bad smell is gone..
What I need to look in my a/c system to fix this issue?
I have a MC R56 2007, STD, and (49k)
PD: my english is very bad sorry.
There is a condensate drain tube from the evaporator under the car, it is probably partially plugged up with mildew, dirt, etc and staying in your houseing and causing the smell. Try backflushing it gently with water and a little bleach. then flush it several times with fresh water. Either that or there is a dead critter in one of your cooling ducts.
where do i find the tube in an 03
I've had the same problem ever since I took the car in for its first service. This is perplexing to me because they said they changed the cabin filter and then the car started stinking when the AC is turned on. Oddly, it never did this before the service! I'll check this out and see if it's dirty, then call and complain.
Smelly A/C
I had smells coming from the A/C and after several trips to the dealership, I still had 'em. The thing that helped, and this is after also replacing the filter under the glove box and making sure there is no blockage with respect to the condensate release, is to make sure to run the A/C with fresh air coming in on the last mile or so of every trip with your MINI during which you run your A/C. In order to get the coldest air coming through your MINI's A/C system, recirculation is the best. You are continually cooling your air with no outside air coming in. But, if you don't introduce outside air, you essentially are running a closed air system, and this will set up a mold and/or stale air condition. So, when you are heading to your destination or back home, hit the recirc button so you come off of that mode. That should help!
The drain is located under the HVAC box and is #4 in the pic, its drain out near the under tunnel of your MINI right near the exhaust heat protection shroud, towards the body. If you have water dripping from there after you run the air conditioner for a while , most likely its not clogged, but good to check.
Also when you replace the filter there might be dirt and debris in there make sure to get all the junk out around the filter sides. Those filters can get really dirty.
http://www.ecstuning.com/Search/SiteSearch/64111504285/
Most people have not changed there Cabin filter and its very dirty.
Goes right in there on the passenger side foot well and has a lid to close the box up.
#2 is the filter.
Most people go with the active carbon filters is it absorbs the smell.
Here is the regular Cabin Filter:
http://www.ecstuning.com/Search/SiteSearch/64319127515/
Here is the Active carbon one:
http://www.ecstuning.com/Search/SiteSearch/64319127516/
#2 is the filter.
Tussen (02-01-2024)
Steffen.Johnson
08-23-2015 08:30 PM
