Horn(s) Issue
Horn(s) Issue
Ever since last winter I have had an issue with either one horn working or the other but seldom both. Sometimes I have no horns at all.
I have checked the wiring and everything seems good. Usually after messing with the wires one horn will start working and the other won't anymore or vis versa.
Is there something I should be looking for or a way to have dual horns like the car is supposed to?
Thanks all!
Thanks all!
As it turns out I found simple cure for now. The stock horns must have an issue with bad contacts inside of them (perhaps from water). I hit the defective horn with a screwdriver multiple times while someone was holding down the horn switch on the steering wheel and slowly the horn started to come back to life. At this point both horns are working perfectly.
trw92a
08-26-2015 01:47 PM
