09 Water Pump Failure - Damage
After less than 90 days my S Convertible overheated on a day of over 100 degrees, thought it odd, added coolant and moved on. A few days later, only 80 degrees, it overheated again. This time I took it to the dealer and come to find out the impeller on the water pump failed.
I guess the question is, what other's experience out there is, possible damage to the engine and other parts might be??
Any experience with Mini customer service, or ??
I took my '07 MINI S for it's 15,000 mile oil change on Saturday, and Roadshow MINI in Cordova, TN tells me my waterpump is leaking and that I should replace it immediately (at a cost of over $1300!). The trouble is, I haven't seen any evidence of coolant leaking under the car, nor has the temp been out of operating range. Since the car is no longer under warranty I am going to try to find a mechanic that can work on my MINI here in Hooterville. I am skeptical there is even a problem.
I would be extremely grateful if someone would be kind enough to point me in the direction of an upgrade in the way of a water pump should I indeed be faced with a repair. If not an upgrade, a less expensive OEM dealer would be good as well.
THANKS!
THANKS!
How are you out of warranty in 2 years and 15,000 miles????
If it's an R52 the P/N would be 1151752012.
I have less than 3K miles on my "S", took it into the shop because of a harmonic type noise I was getting from the engine bay! (I have had the car less than 90 days...) Seems the water pump failed. As well as the iPod interface (3 times)....
Mini service has fixed everything to satisfaction, but.......build quality is questionable.
A water pump is a Epic Fail in my book, end result can be catastrophic engine failure....rebuild at the minimum!
R50/53 More supercharger hulabaloo
one73ronin
23
09-22-2015 09:56 AM
mimaal
09-04-2015 09:09 AM
