Got a Puncture with conventional tires
I'm not sure but I believe it has to do with the fact that the sidewall is designed to flex a lot and there isn't nearly as much strength in the sidewall as compared to the main tread surface.
I've heard it said that it is "law" but absolutely can't confirm that but can confirm that no reputable tire repair will plug or patch a sidewall and usually not within 1/2 inch of the edge of the tread.
found this on a National Highway Traffic Safety Administration page (part of DOT) Punctures through the tread can be repaired if they are not too large, but punctures to the sidewall should not be repaired. Not exactly a stern rule but a policy statement anyway....
And then there's some additional reading
http://www.retread.org/PDF/Rolwing.pdf
it's a tire conspiracy!!! must be buschs' fault . side walls if i remember are 2 ply and under tread is 4 ply . when you tear or get a hole in side wall ; the tire will quickly degrade . and rip apart and kill everyone in your vicinity when you roll and flip into oncoming traffic;but a plug would be cheaper .
Sidewall issue
Tire sidewalls are too thin and have too much flexibility in them to allow a proper repair. Any repair to the sidewall will quickly degrade as the sidewall flexes and separates from the repair. A plug in the sidewall would be futile as the rubber is thinnest at the sidewalls and the plug would soon loose adhesion to the sidewall rubber. I always prefer a patch to a plug (in the tread). Plugs are great for getting you to a service station or tire repair shop, but I wouldn't bet the farm on a plug alone; patch it...but I digress.
I would, IMHO, just suck it up and replace the tire.
