Knocking from Engine Bay behind Glovebox
Old 12-08-2009 | 02:26 AM
Giants9595's Avatar
Giants9595
I am hearing a loud pop when in first gear. It happens when I hit the gas and let off the gas. Also at idle or lower rps, I can hear a rattle behind the glovebox which is where the pop seems to also be coming from. What could this be?!?!?!
Old 12-08-2009 | 07:36 AM
AutoXCooper.com's Avatar
AutoXCooper.com
well depending on miles and type of MINI and if the sound is outside the interior I'd check the pass side motor mount and the pass side front control arm bushing. More details will help NAM members help you better.
Old 12-08-2009 | 08:11 AM
Bigshot's Avatar
Bigshot
on the motor mount.
Old 12-08-2009 | 08:23 AM
FrenchyR53's Avatar
FrenchyR53
I agree with both posts prior..had the same thing and my motor mount was busted again (second time in 4 years)..no more knocking now!
Old 12-08-2009 | 08:31 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Depending on when you MINI was manufactured....TSW ( Texas Speed Works ) has a newly designed Engine Mount for the late 04, 05-06 models.....It replaces the original mount, and is void of OEM mount flaws......It should last much longer and function much better too.
Old 12-08-2009 | 11:42 AM
Giants9595's Avatar
Giants9595
I will check out the motor mount. Can I see it from the top of the engine or do I need to jack the car up and look from the bottom? Is it a certain color?
Old 12-08-2009 | 12:30 PM
AutoXCooper.com
If you MINI was built in or after Dec 2003 you want a TSW mount.
the OEM one leaks and while you can't see if it's bad you can see that it's leaked all over the frame rail on the pass side. Like This
Old 12-08-2009 | 01:19 PM
Giants9595's Avatar
Giants9595
I have a 2006 MCS with about 45000 miles on it. What does mine look like? Thanks for all the help!
Giants9595's Avatar
Giants9595
NVM I see that that mount above is the same for mine.
Old 12-08-2009 | 04:10 PM
AXracer's Avatar
AXracer
Check the motor mount for leakage, when they leak the fluid out they will start to make noise. If there is dark stain under it like in the picture above its shot.
Also, I have seen the crank dampner pulleys start comming apart and make knocking noises as well, ussually this will only be under accell. If thats bad its a good reason to get a lite weight one.
Old 12-08-2009 | 09:42 PM
Giants9595's Avatar
Giants9595
There is definitely some fluid under the motor mount. I have 45,000 miles on a 2006 MCS. Will this be covered under warranty? Should I supply the dealer with the TSW part and just have them cover the labor? $200 seems a bit steep...? Do these mounts usually go out in 45,000 miles??
Old 12-09-2009 | 04:27 AM
AXracer's Avatar
AXracer
It should be covered under the 4/50 factory warranty.
Most dealers will not install aftermarket parts even if you bring it to them.
Old 12-09-2009 | 06:19 AM
AutoXCooper.com
AXracer is right about the dealerships and warranty. A few dealers will even replace that mount after the warranty.
If you can get it replaced for free that's your best bet for now. If you get a free one plan on buying your next one after it fails in less then 45K.
We've seen the OEM leak in less then 25K and some make it all the way to 65K it's all about mods and driving style.
The mount was never deemed a "safety" issue therefor was never recalled.
Old 12-14-2009 | 04:45 PM
MLPearson79's Avatar
MLPearson79
I would do the OEM for now also, if it will be covered under warranty. Mine went just out of warranty and I've been holding off on replacing it out of procrastination. Just purchased one of the TSW mounts today (although direct from TSW because their coupon saved me a little under $10 after shipping). Can't wait to get rid of my leaky OEM (original with 98k miles!) motor mount!
Kimolaoha
07-05-2023 02:04 PM
blackie
01-18-2017 10:57 PM
blackie
01-18-2017 10:56 PM
makg
08-21-2015 03:49 AM
chicohuahua
22
08-20-2015 12:17 PM
