Problem with the air filter box
slip joint pliers have always worked for me- http://toolsandmore.us/slipjointpliers1.aspx
If you can't get the OEM clip to work....a standard hose clamp might be made to work (Width is a bit off...but it will do the job). But a set of pliers should clipthe OEM one fine.....just slip the clip to as close to the correct location as you can, squeeze the two parts together, slide it over and let go...VOLA!!
07-16-2020 01:54 PM
silence2-38554
98
09-21-2016 03:52 PM
polotska
08-23-2015 10:10 AM
minipopkart
08-13-2015 06:22 AM
