Run Flat Tires: Second Question
Thank you, all, for answering my first question (should I change from run-flats)..... a follow up (which sounds naive, I know): can I put 17" non-run-flat tires on my 17" crown spoke rims or do I need to buy new 16" rims? Do you have any recommendations about tire brands?
on
Have at it with Tire Rack for some good advice or any local tire shop should also be able to give you some very good suggestions. Tell them what you are looking for performance and tire life wise and let them point you in the right direction. Just make sure they handle a variety of brands or they may try to stick you with their house favorite
on
You may want to talk to Alex at TireRack. He is the MINI guy. You will find his posts in the Tires, Wheels, & Brakes Forum.
Just in case your original question was in regards to the ride quality of a non run-flat 205/45/17 being smooth enough, it is. You don't need to go with a 16 to smooth out the ride. It is the run-flat's stiff sidewall causing the problem, not the low profile.
I too have had good luck with Tire Rack in the past so +1 on the above post.
ltjpunk7
09-06-2015 07:32 AM
Powershift
08-16-2015 05:14 PM
sabjcw
08-14-2015 07:40 AM
