engine wrning light...brrrrrrrr...safe to drive?
I started my car this morning no problem...but then i heard it warming up and the engine was almost stalling ...and a engine light that looks like a engine block came on...the light looks like have of it is filled in with yellow.
i looked in the manual and can't find it...
You need to have it checked out by service. This is called "limp" mode. Your MINI will be operating at half power till you get the problem resolved.
If you have a OBDII code reader you can reset all check engine lights and it will go away, but if you're not finding out what's causing it you're asking for trouble down the road.
I had the same thing happen as I was leaving work Tuesday evening (9800 miles on the odometer). Engine ran rough, like cylinders missing, and lots of gray exhaust, then the same yellow "engine operating in reduced mode" light came on. I was able to "limp" down to the dealership, they promptly took the car in (mechanics had already left for the day) and issued me a loaner. The next day they found the fuel pump was bad and replaced it no questions.
it was -5 here this morning....and i never got any limp mode message...just the engine black picture above the steering wheel. I drove it around al day and no problems since...
I live in the south where it does not get as cold as where you guys live, but the problem is universal whether the temps are cold or whether they are hot. I've had mine 2009 clubman s act up twice in the first 36,000 miles. Sevice people at TWO different Mini dealerships have said the a poor high pressure fuel pump is causing all of our problems and until they re-design or get another supplier, we are going to continue to have problems.
07-16-2020 12:54 PM
