Just bought used Mini Cooper S (R53) - Not Very hAPPY
Old 12-20-2009 | 08:14 AM
Omarshareef's Avatar
Omarshareef
Hi to all and happy to join in the community. I just bought my 1st mini, not brand new but used with 20000kms plus (2006). Apparently my 1st mistake was that i rushed the buying process that i failed to do the usual routine pre-check list. I didnt know about this website only after having purchased the cooper s.
The problem lies with driving the cooper. The engine is excellent but the ride is questionable. Theres this dreaded knocking or rattling sound which comes from both left and right front chassis. I can feel the knocking sound from the steering wheel itself and also the fact that the steering wheel has some sort of play. Could this be the following:-
- Steering rack?
- steering column?
- front wheel bearings?
- worn out front bushes?
- worn out ball joints or tie rods?
- bad cv joints? do i need to replace both left and right axle? etc
- any other ideas?
Apart from that, its also making this strange sound when cruising (70mph), i cant described it by text but i know its not the supercharger. The supercharger sounds great though
Any ideas or experience from the above?
Old 12-20-2009 | 09:29 AM
veggivet's Avatar
veggivet
Could be any of the above, but bad bearings usually sound worse when turning. Sounds like the car should be thoroughly inspected by a mechanic, preferably one who is familiar with MINI's. Or maybe the H3 has visited a curse upon your new addition. Hope things get sorted out soon and for not much $$. Once that happens, you'll love driving it! Welcome aboard.
Old 12-20-2009 | 09:47 AM
ricbow's Avatar
ricbow
sounds like worn out front bushings
Old 12-20-2009 | 04:04 PM
Frisco's Avatar
Frisco
Motor mount.
Look for oil spray (dirty brown) in that area.
Good luck, and keep us informed.
Old 12-21-2009 | 07:22 AM
Omarshareef
My Mini now is at the stealership as i couldnt get the stick to shift to reverse gear. I dont know what really happened but i do know that the dealership had replaced a brand new o.e clutch kit last week. Now i cant put the stick in Reverse, 1st and 2nd. Only 4th, 5th and 6th gears are functioning. Talk about a very bad week
Old 12-21-2009 | 07:54 AM
JAB 67's Avatar
JAB 67
If this car needed a new clutch after only about 15,000 miles, the whole car may have been abused, in which case anything is possible. Good luck.
Old 12-21-2009 | 11:09 AM
WordIsBorn's Avatar
WordIsBorn
Sounds like a clip holding the shift cables was not seated properly when re-installed and probably popped out, allowing the whole cable/sheath to move when you shift. That should be an easy fix. The other issues seem to have been covered well by previous posts. Good luck!
Old 12-21-2009 | 01:32 PM
Mr Ballyhoo's Avatar
Mr Ballyhoo
Are you getting any shaking/vibrations in the steering wheel when at higher speeds. Also does the car seem to track the road a lot. I say a lot because it's going to track a little bit but if it's riding like it's stuck on rails you may want to have the bushings checked. I just had mine redone about a month back along with some other work and it took away the major tracking issues along with the bad vibration at higher speeds.
Is the sound like marbles rolling in a tin coffee can?
Old 12-21-2009 | 03:28 PM
Omarshareef
The car seems to track to the left everytime it wishes to go straight though theres no vibration during high speed. Yes, the sound is similar to like marbles rolling in a tin coffee can if i drive the car around uneven surfaced roads or cobbled roads or some 's***' roads. Most probably it could be the bushes and some say its the wheel bearings but i'll keep you guys posted along the way. Mind you, with all this problems, i'm beginning to like the cooper more than before.
Old 12-21-2009 | 03:46 PM
Capt_bj's Avatar
Capt_bj
the most common front suspension failure item seems to be the lower control arm bushing which have been know to go out as early as 30,000 miles. Unfortunately they are a bit of a PIA to replace but on the good side a POLY replacement is available and once you put those in you should expect LONG life.
As stated I find wheel bearing problems to be more appearent in wheel speed and especailly turning, while the control arm more noticable when the suspension "works" .... does that make sense?
Do the easy check for a wheel bearing problem.
1. Jack up the wheel
2. Grap at 3 and 9 o'clock
3. Try to rock the wheel back and forth like you were pulling it off the lugs/studs.
If you get any movement the bearings are questionable. Much movement and they are shot. I prefer to do this test with the wheel off and rock the rotor .... you'll really see movement if there's a problem.
If so
Bad News is you can't replace just the bearings (easily)
Good News is the sealed hubs swap out fairly easily . . .
Old 12-22-2009 | 06:33 AM
Omarshareef
If so
Thanx for the detailed information. I will pass this info to the technician tomorrow and we'll see how things go from there. Sadly i've been dying to get hold of front polybushes but i heard their factory in England was on fire that they had to stop production. I will try to find another alternative if available.
iggi
17
09-02-2023 04:06 PM
theateist
07-02-2017 03:21 PM
cjsdad
08-11-2015 09:46 AM
08-07-2015 10:51 AM
08-07-2015 09:02 AM
