Clutch Pedal
Clutch Pedal
When i depress my pedal there is a spot of very mild resistance and it makes a soft click noise when i go past it. This happens with the car out of gear and has done it since mile 0. My 07 MCS did not make this noise. How worried should i be? Granted i have waited nearly 13k so far...
It's either the pivot on the Clutch Master hitting in its bracket (fixed by cutting a plastic washer into a C shape and installing it on the pivot rod) or the clutch pedal itself has a portion of plastic that hits on part of the plumbing for the slave cylinder. That is fixed by grinding or filing a small portion of your clutch pedal.... I know it sounds extreme, but you'll see when you look at it. The problem with putting your head down there and using your hand to opperate the clutch, is it doesn't go at the same angle as your foot would, so its hard to re-create the noise. Good luck
drrigg
05-27-2022 03:31 AM
eliseo1981
11-02-2015 11:24 AM
10-01-2015 12:13 PM
09-28-2015 09:13 AM
