Rear Wiper Spray Clogged
My rear wiper sprayer isn't spraying evenly. I got a safety pin and unclogged it, which helped a little. For the most part is sprays a stream very close to the bottom and hardly reaches the top. I pulled the little sprayer nozzle off and made sure it was clean. As it happens, you can aim them, which doesn't really help. It either shoots over the car or 3cm in front. Any ideas? It should be an mist, not a stream, right?
On my last 03 MC it was an even spray, not a stream. It was also clogged at some point, but worked great after I got a safety pin.
I just popped the little nozzle off (smaller than a tic tac) and there seems to be nothing blocking the flow. I'll let it soak just to make sure, but it appears to be pretty clean. The nozzle adjusts (rotationally) so I'll experiment with placement as well. It seems to have good pressure, shoots 3-4' over my car when its pointed straight up.
This happened to me last winter. I don't know if it's the result of cleaning it, but mine (11/03 build MCS) seems to have more of a forceful stream than a spray coming out of it. It took me several tries adjusting it so that it would actually hose down the glass - the slightest bump would get it streaming out the wrong way. But now that I've got it fine-tuned, it works better than ever.
Might seem a little off topic, but does anyone know if the wipe blade is suppose to lock in on an '03 MCS? I have the same issue with the wiper jet not spraying and in the process of cleaning it I replaced the wiper blade. I noticed it just seems to sit in the arm with the pressure of the arm holding it against the glass. Is this normal, or is my wiper arm broken?
I replaced the whole wiper, plastic part and rubber blade. However, the arm that the wiper connects to doesn't have like a lock to hold the blade. It's just got the groove where the wiper sits and it looks like it's all in tact nothing broken. I'm just used to wipers locking in somehow, and this doesn't appear to do that.
hi guys, nice thread. My fix was pulling off the plastic cover and then using a pump-air pellet rifle, and aiming the outside hole and shooting a puff of compressed air... one shot of compressed air (quite strong), and some gunk came flying out the inside hole.
The hole itself is a 90 bend, so you can't even thread fishing wire through it. What I did find was blowing into the hole after clearing it, was that you can actually feel the airflow being smooth and clear. Before clearing it, blowing into the hole, you could feel that something was stuck, but was impossible to get out.
07-16-2020 12:54 PM
