Timing chain rattle cured or not?
Old 02-09-2010, 06:15 PM
orangecrush's Avatar
orangecrush
orangecrush is offline
I'll highlight this because apparently some people can't read...
This post is only for those that have/had the engine rattle from the timing chain and took the car to be repaired.
I really don't want to hear stories of how you took it in and they couldn't duplicate it or you've had it, blah, blah, blah.
Two simple questions.
For those that have had the timing chain rattle and had it repaired...
1) Did it cure the problem?
2) how many miles on the car since you had it repaired?
Thanks,
Mark
Old 02-09-2010, 08:06 PM
rdwatt's Avatar
rdwatt
rdwatt is offline
Mark:Tensioner replaced @ 22,495 miles...rattle gone. Currently 25,790 miles and noproblems.
Old 02-09-2010, 08:08 PM
nicknbecka's Avatar
nicknbecka
nicknbecka is offline
Replaced at ~50,000, currently at 93,200 with no returning rattle or timing chain problems.
Old 02-10-2010, 09:48 AM
KenL's Avatar
KenL
KenL is offline
I'm in the UK.
Had mine fixed in May 2009, car had only covered about 1k miles.
Now done 11k miles, never heard it since despite some cold (< -5C) temperatures over here in Bonnie Scotland.
I think the issue is no more if dealers are doing their job correctly.
Old 02-10-2010, 10:53 AM
MINIdave's Avatar
MINIdave
MINIdave is offline
'09 MCS, chain tensioner only replaced just under 3K, now have 14K with no noise return.
Old 02-10-2010, 11:02 AM
cdean's Avatar
cdean
cdean is offline
Chain Rattle
Replaced at about 12,000K Now have 17,000K Have not heard it since and I live in Chicago where it has been cold and snowy...
Old 02-10-2010, 12:04 PM
torobud's Avatar
torobud
torobud is offline
1) Nope
2) After which repair attempt?? Total of 22,000 miles and it is going back in tomorrow for repair attempt number 4? 5?
Old 02-10-2010, 08:50 PM
oldMGguy's Avatar
oldMGguy
oldMGguy is offline
3 repairs: January 2009 (tensioner piston replaced, still rattled), May 2009 (full monty repair, chain rattle returned 3500 miles later), and January 2010 (latest revised tensioner piston installed, almost new chain well within stretch deflection limits). So far so good ...
According to the PDX MINI dealer, BMW revised the tensioner piston twice in 2009. The latest tensioner is 11-31-7-597-895.
Old 02-10-2010, 09:10 PM
wandrur's Avatar
wandrur
wandrur is offline
Moderator
Tensioner replaced on February 5th, 2010. I mentioned it once, they asked no questions and did the replacement. Haven't heard that terrible sound since.
Old 02-11-2010, 08:13 AM
TerryD's Avatar
TerryD
TerryD is offline
Repair done about 5000 miles ago. All is well.
Old 02-11-2010, 11:12 AM
wandrur's Avatar
wandrur
wandrur is offline
Moderator
Let's help keep this thread on the specific topic that the OP requests--ONLY resolutions (or attempted resolutions) and results.
For more information on the cold start issue, check these threads (and search):
https://www.northamericanmotoring.co...-database.html
https://www.northamericanmotoring.co...t-chatter.html
Please keep discussion of the issue in those threads and not this one.
THANKS!!
Old 02-11-2010, 11:32 AM
sequence's Avatar
sequence
sequence is offline
jeez y're a moderator now?
Old 02-12-2010, 02:45 PM
russr's Avatar
russr
russr is offline
I had my chain tensioner replaced in March 2009 when my car had ~13K miles on it. This December (~17.5K miles), the noise came back and was more frequent and louder than ever before. Car is back at the dealer as I type.
Old 02-12-2010, 05:43 PM
M1sterWhite's Avatar
M1sterWhite
M1sterWhite is offline
Had my new to me 2007 MCS in April 2009 for the fix. Solved the problem completely until Nov when the noise occured again - but very infrequent. Since it is at the dealer for a few weeks for a new cylinder head I am getting the latest fix applied at the same time.
Old 02-12-2010, 08:43 PM
ladisney's Avatar
ladisney
ladisney is offline
My 07 S went in on a truck over two weeks ago and I got it back today. 150 miles trip home and nary a clatter. A little over 23k when it went in. They replaced the cam gear, tensioner, cam chain, guides, etc. They removed the head for inspection as the chain had apparently slipped. Over $2,200 all together, I'm sure glad it was under warranty. Looking at the pictures I'm wondering, is this a Mellow yellow problem?
Old 02-14-2010, 05:46 PM
HIBSFAN's Avatar
HIBSFAN
HIBSFAN is offline
My 07 MCS had the tensioner changed at approx. 15k. Since then, no problems, although to be fair freezing weather is rare here in Central Cal.
So far, so good.
Old 02-14-2010, 05:51 PM
orangecrush
So far, so good.
How many miles on it now?
Thanks,
Mark
Old 02-14-2010, 08:38 PM
BMBULBE's Avatar
BMBULBE
BMBULBE is offline
My dealer fixed the chain rattle about 500 miles ago. It has not returned.
Old 02-15-2010, 05:06 AM
JHB141's Avatar
JHB141
JHB141 is offline
Replaced at about 30k, now almost 32, so far so good.
Old 02-15-2010, 05:18 AM
elpappy's Avatar
elpappy
elpappy is offline
Replaced last Fri. at 32,000 (only had it happen like 4 times ever) because of the "cold" during the snow storms in VA. Hasn't come back nor has it been "cold" since. But here's hoping right?
Old 02-15-2010, 05:32 AM
DrewN's Avatar
DrewN
DrewN is offline
Tagged. I just had the full replacement last week, so I'll check in after I put some miles in.
Old 02-15-2010, 03:24 PM
sossol's Avatar
sossol
sossol is offline
This is a long shot, but has anyone here made a sound recording of the timing chain rattle? I just today noticed a ticking sound on my wife's 89k-mile 03 MCS that I don't remember hearing before. She says that it sounds normal to her, but it doesn't to me. The caveat is that I have rarely driven this car since I traded cars with her. I checked the oil, and it was low, but not much (though it uses up noticeably more oil than my 130k E30 318is). The last oil change was August 09, or maybe 4000 miles ago. I've been changing it once in early spring and in the fall, and we average less than 10k per year.
Ours sounds rather a lot like the failed tensioner in my 318is.
I will be doing the repair myself, so if anyone has done it and has any pointers that don't involve taking it to a stealer, I'd be grateful to hear them. It was a 10-minute job on the E30's longitudinal engine.
Neil
03 MCS
91 318is
86 M535i (for sale)
Old 02-15-2010, 03:43 PM
orangecrush
deleted... didn't follow my own request.
Old 02-15-2010, 03:57 PM
sossol's Avatar
sossol
sossol is offline
You mean like this?
Did you mean to link to or attach a sound bite? I'm getting nothing.
Old 02-15-2010, 04:14 PM
orangecrush
Here's a link to a thread with a video... I didn't want any discussion on this is thread.
Thanks,
Mark
Quick Reply: Timing chain rattle cured or not?
