Brake lights dont light up.
on
I have a 2004 MINI Cooper S. Clear taillights and chrome bulbs. the running lights work but when I press on the brakes only my 3rd brake light under the tailwing works. i checked the brake light fuse. any reason they would be lit while running but not get brighter once the brakes are pushed? could it be the bulbs? thanks.
The bulbs are dual filament. One filament only illuminates for the brake and the other only for the running light. The brake filament can burn out and the running light filament can continue working (or vice versa).
So the bulbs could be the problem, but it would be odd if the brake lights on both sides suddenly stopped working at the same time. If that's what happened, something else might be causing the problem.
on
Thank you both of you!
on
07-16-2020 12:54 PM
12-23-2015 10:36 AM
TunedGP
10-01-2015 04:18 PM
