CarChip Data Logger
Call them asd ask about Fuel pressure and Battery Voltage.
I don;t think the MINI will tell you those values.
Here are the values I have gotten out of my MINI using
the ELM-ISO from scantool.net ($90.00)
PIDs supported by MINI Cooper 2002
Service 1 PIDs
PID Sensor Returned value
00 PIDs supported H'BE3EB811
B'10111110001111101011100000010001
1,3,4,5,6,7,B,C,D,E,F,11,13,14,15,1C,20
01 System tests status
03 Fuel system status 0x01 = Open loop
0x02 = Closed loop using O2
0x04 = Open loop driving conditions
0x10 = Open loop system fault
0x20 = Closed loop but system fault
04 Calculated Load Value 0% to 100% 100% = 0xFF
05 Engine Coolant Temp Degree C + 40
06 Short Term Fuel Trim -100% to +99.22% (0% = 0x80)
07 Long Term Fuel Trim -100% to +99.22% (0% = 0x80)
0B Intake Manifold Pressure kPa
0C Engine RPM RPM*4
0D Vehicle Speed KM
0E Ignition Timing Advance 0.5 degree-per-bit 0.0 degree=0x80
0F Air Intake Temperature Degree C + 40
11 Absolute Throttle Position 0%-100% 100%=0xFF
13 Location of O2 sensor
14 O2 Sensor 1 Voltage & Short-term trim -100% to +99.22%
15 O2 Sensor 2 Voltage & Short-term trim -100% to +99.22%
1C OBD standard
20 More PIDs 80000000
21 KM travelled while MIL lit
Service 1 PIDs
0C Engine RPM RPM*4
0D Vehicle Speed KM
1C OBD standard
