tachometer/speedo/dash lights acting up
i have an 02 cooper s and i was driving this afternoon and the dash lights started blinking all on and off and the tachometer and speedometer started intermitently switching off and on... as well as the fuel gauge moving all over and the temp gauge going all over.. then it clears for a few minutes and starts again. i checked the connections to the battery, and all the fuses. in the fuse box under the footwell the fifth fuse down on the left is marked as being one for the gauges but i can get no power to either side of it no matter what i do (ignition on/engine running/lights on etc.) ... has anyone else had any problems like this? ive heard of similar issues where the car wont start, but mine starts and runs fine
![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
how old is your battery?
As a battery gets old it can suck volts from the rest of the system, and when they see low volts they go a wee bit crazy . . .
I'd usually send you to a good auto part chain for a free test ... and you may still want to do this . . . 'cept lately MINI batteries have been fooling the testers IMHO.
IMHO, if in doubt, buy a battery and do't be surprised if your problems go away.
EDIT - a GOOD battery . . . all the electronics demand a GOOD battery . . .
andrewjg1994
01-29-2021 07:45 PM
Getrieben
08-15-2015 09:09 PM
Ambient Thermal Management
08-07-2015 12:27 PM
