Oil Leak
on
Could be your oil cooler heat exchanger. I've heard those tend to leak, and I actually have a leak in my car too and that's one of the things I need to check. If the car leaks while standing still, it could be an oil pan problem. If the car only leaks while moving, and perhaps only deposits a few drops on the floor after you've returned home, that means it's only leaking when the oil is pressurized. That would be the case if it were the oil cooler.
on
on
