2010 gremlins? Boot rattle, frozen door locks?
I was pretty happy with my 2006 MCSc, and the 3 BMWs I owned before that. No real problems to speak of. I was expecting my 2010 MC to be even better. I was looking for a simpler, very low maintenance, easy going car.
Just a few days after picking it up in December I had a check engine light (and a few cases where the car wouldn't start) but it was quickly diagnosed and fixed. I forget what was wrong. I didn't think it was a huge deal... but...
Ever since day 1 I've had this rattle from the rear of the car, only in the mornings for maybe the first 15 minutes of driving. First I had the dealer inspect the suspension but nothing. Recently (After putting it off for a long time as I suspected they wouldn't fix it) I spent the time to take it to the dealer to have them look at it. They diagnosed it as a "sticker failure" or something like that on the paperwork and replaced the sticker and the striker on the hatch. But it didn't help at all.
I could even live with that... it's relatively minor... but, now for the 2nd time in two weeks, the car refused to let me open the driver side door. I have comfort access so I pressed the button to unlock the car. It unlocked, but the driver door latch was frozen. The first time I just opened the passenger door, reached over and open the car from the inside. This time I just used the remote to lower the windows and unlock the door from the inside.
I did ask the dealer to look but as you'd expect, they could do nothing. No fault codes were stored, it's impossible to reproduce, so nothing was done.
It's a bit worrying as being able to get into the car is a basic requirement to me. And it is a safety concern too. What if I lent the car to someone and it did this? What if they were parked somewhere and in a situation where they didn't have time to figure out how to finagle there way into the car?
I had heard of some issues with comfort access, but I had hoped they would have been fixed by the 2010 models. I guess not. :(
Anyway, before I spend time writing a formal letter to MINI USA and the NHTSA about this, am wondering if anyone else has had these problems and gotten a resolution?
my hatch was making all kinds of noises on rough roads and I lubed the stricker thinking it was dry but that didn't help. Then I found the two adjustable stops that are in the hatch itself that hit the body when you close it. The should be a clear plastic on the body where these make contact and I put some greese on those and haven't had a noise since.
I had the same boot rattle issue and I put some masking tape around the U-shaped hook, meaning on top of it and down both sides. Even though it solved the issue, I felt bad about putting that much tape. Turns out it only needed it at the top of the "U." It's been very quiet back there since.
07-16-2020 12:54 PM
R50/53 R53 Chrono Pack - gauge?
missinmyjeep
08-22-2015 07:13 PM
