brake fluid bleeding question
I picked up some Valvoline synthetic DOT 3 and 4 brake fluid today and I'm planning to bleed out the fluid on my MCS this weekend. I don't plan on flushing out the entire system. Since after bleeding each caliper, I have to top off the master cylinder, I'm worried about mixing the new fluid w/ the existing in there already. Is there a problem of mixing the new brake fluid w/ the existing fluid in the MCS? thanks
It's not a hard job.
Rich
Yeah, that's a bit much. I can do mine with one bottle of ATE superblue with plenty to spare with a pressure bleeder, and those bottles are much smaller than 32 ounces.
On the other hand, once you open a bottle of brake fluid it's probably best to discard any that's leftover anyway (unless you're using it in the near future); over time, once the seal on the can is broken, it can pick up water, which is a no-no for brake fluid, so if you're using a whole bottle it's not like you're wasting anything.
Thats one of the benefits of using Ate brake fluid. You can alternate between Superblue and 200 (amber in color) so you know when you have a good flush without wasting fluid. One bottle should be enough.
07-16-2020 12:54 PM
minimofo
04-04-2016 07:36 PM
minimofo
12-26-2015 11:45 AM
