You guys are probably sick of this question, but clutch bleeding...
I hope someone can help me. Here's what I did...
I flushed the brake fluid on my '03 MCS, using a Motive pressure bleeder.
That went well, then I went to flush the clutch.
1st I opened the bleeder with the pressure bleeder in place and pressurized to about 12psi, nothing came out. I thought maybe the bleed screw was plugged so I started unscrewing it, and after maybe a full turn fluid started coming out (I had detached the pressure bleeder). I pulled the bleed screw all the way out, plugged the hole it came out of, checked the screw and it was fine, I just now knew that I had to turn it a lot to get it to open.
Is it normal to have to turn the bleeder screw so far to get flow?
Now that I had that figured out I pressurized the system and flushed. After clean fluid was coming out, I tightened the bleed screw and check the pedal.
Nothing, totally soft, doesn't stick to the floor, but completely soft.
At this point I did the research on this site I should have done before I started, found k-huevo's great instructions, made a tool to compress the slave, and bled the clutch again, still no pedal.
I have now done this 5+ times and I am not gaining.
There is some fluid in the slave boot. I took the boot off for the last couple attempts at bleeding, and I don't see fluid coming out, but it is wet around the rod.
I am guessing I need a new slave cylinder, but it worked perfectly fine before I messed with it.
So, if you haven't got bored and moved on by now, do I need a new slave? Could I have damaged the slave when compressing it?
Am I still doing something wrong with the bleeding?
Another thing I tried was gravity bleeding, compressing the slave cylinder with the bleeder valve open, and a hose full of fluid attached. I did get some air bubbles, so I repeated this. At this point I get no air by the pressure bleeder/compressed slave technique, or by gravity technique.
Help.
Thanks for reading,
-Joe
Help.
Thanks for reading,
-Joe
andrewjg1994
01-29-2021 07:45 PM
R50/53 Replacement AC compressor??
PrimePower
08-16-2015 06:29 PM
Colt45Magnus
08-12-2015 06:43 AM
