Cooper S Engine Code Issues
Hi Welcome to NAM.
First, in case you didn't know, typing in caps is the internet equivalent to being yelled at, so it's something you might want to keep in mind when seeking responses![Wink](https://www.northamericanmotoring.com/forums/images/smilies/wink.gif)
I've never seen the codes formatted in that manner so I'm not really sure where to check to convert them to OBDII "P codes"; but I can tell you P1477 is listed as ""Leakage Diagnostic Pump Reed Switch Did Not Open"
Do you have any symptoms ontop of the codes to help diagonose the problem? Generally to clear the airbag codes requires a trip to the dealer.
07-16-2020 12:54 PM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
