Are the heated seats pulsing heat?
Old 09-27-2002 | 12:34 PM
joshua's Avatar
joshua
my seats heat up then die then might heat up again. is this typical?
shouldn't they be constant? like an electrical blanket?
i am wondering if mine are broken or if that is how they are.
thanks
ops:
Old 09-27-2002 | 12:53 PM
0wen0's Avatar
0wen0
I have only used heated seats in a Mercedes. Those heated seats had a two settings. If you set it on the high setting, It would heat up and stary really hot for a little while then switch itself down to the "normal" heat setting. I don't know if that helps, but I thought I would throw it in anyways.
Old 09-27-2002 | 01:05 PM
Chobe's Avatar
Chobe
tHEY GO ON AND OF TO PREVENT YOU FROM HAVING HEMORROID FROM TO MUCH HEAT
THATS WHAT THEY TOLD ME?
Old 09-27-2002 | 02:58 PM
joshua's Avatar
joshua
so mine are not broken?
Old 09-27-2002 | 04:01 PM
Chobe's Avatar
Chobe
NO, JUST CHECK, MINE AND YOU ARE RIGHT THE GO ON AND OFF, NO PROBLEM IN YOURE MINI.
I THINK THAT HAVING A MINI COOPER IS A GOOD SCHOOL TO BECOMING A PARENT
HAPPY MOTORING.
Old 10-03-2002 | 09:18 AM
Pebble's Avatar
Pebble
Caps lock Chobe!
Pebble
:smile:
Old 10-03-2002 | 09:34 AM
sirron's Avatar
sirron
Try loosening your shorts!
patsum
26
05-29-2021 07:29 PM
molala
10-02-2015 02:53 PM
KristaMcCoy
09-12-2015 06:37 PM
Norton70
09-07-2015 06:06 PM
09-03-2015 02:45 PM
