cooling fan + alarm = dead battery?!!!!! HELP
Can someone help me with this issue or direct me where I can solve this problem?
I wan doing my daily drive and when I got home.... my cooling fan was still on.... (normal)..... but I. Noticed it was more than 20min and still did not shut off......... next thing you know..... my alarm goes haywire and now my battery is dead.... can someone help???????
If the fan is staying on that long then the car is getting too hot. Probably the low speed on the radiator fan is not working. Check the boards, there are a few threads about this. I just had to replace my fan assembly for the same reason, the high speed fan would be running for a long time after I turned the car off. Also check the coolant level.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
patsum
26
05-29-2021 06:29 PM
UncDeo
11-04-2019 04:08 AM
