Help with missing items in engine bay
Need help from you guys. I had body work done on my car recently due to an accident that occurred last yr. When i checked the engine bay, there were components that were not replaced but i don't know what they're of or for and i was also unable to find the missing pieces using realoem.com. The area is around the driver side rails or below the intake pipe. Here are the poor quality pics using my blackberry.
Thanks in advance
![](http://cchan918.smugmug.com/photos/868106719_vesUR-L.jpg)
![](http://cchan918.smugmug.com/photos/868106868_ZKa8v-L-1.jpg)
Thanks in advance
![](http://cchan918.smugmug.com/photos/868106988_9rdwq-L.jpg)
There are pics of engine bays in the following threads. Perhaps you could point out what you think is missing:
https://www.northamericanmotoring.co...-pictures.html
https://www.northamericanmotoring.co...-dress-up.html
I'm pretty sure he is talking ot the pressure hoses that just end in midair. They look like part of the A/C system...maybe a evaporator or just the fill for the high and low side missing the caps. I am not familiar with the layout of the engine, but just using a total guess based on my limited experience.
Thanks in advance
Thanks in advance
[IMG]file:///Users/lesrice/Library/Caches/TemporaryItems/moz-screenshot.png[/IMG]
![](http://farm3.static.flickr.com/2354/2255365675_829049c985_o.jpg)
RKW, thanks for the links.
Aside from the caps, this is the item i'm missing and mainly concerned about:
![](http://cchan918.smugmug.com/photos/868988633_NxR3i-L.jpg)
You also seem to be missing the metal bracket that holds the electrical connections for the radiator fan. The same bolt that secures the air conditioner filler tubes (mentioned in posts 3 & 4) also goes thru this bracket. I'm not seeing those electrical connections so they must have routed them differently.
Kimolaoha
07-05-2023 01:04 PM
blackie
01-18-2017 09:56 PM
