Thumping Noise Revisited Any answers
OK, The 2003 MCS has thumping sounds that appear to be in the rear and directly related to a bearing and tire issue. However here is the story, I replaced brakes on all four corners, wheel bearings on left rear (this one was bad) and right front, Half shaft/CV joint on the right front, realiened the wheels, new tires on all four corners, double checked the runout of the tires and wheels (which was OK), and checked the bearings on all 4 with no apparent problems, and it still goes down the road thumping. The thumping starts at about 20 mph and increases and decreases with speed. It is there with the cluch in or out, under acceleration and deceleration.
Any great ideas? What did I miss? Thanks in advance. MiniGSport
Supertractor3
04-07-2017 11:16 AM
