Belt Tensioner Bolt Broke!!!!!!
I F---ed up!!!! I have the new SC pulley on, the belt on and the tensioner stop installed and when I was putting the belt tensioner bolt back on it broke off, now I have a stud in the engine...I have about 1" of the bolt sticking out showing threads, but I don't think I can get a nut on it.....any ideas and where can I get a new belt tensioner bolt.
I need some super duper help here, I am screwed until I can get this taken care of.
I like JAB 67s idea, but I don't think there is enough access. KD makes a studd extractor that can be found at most auto parts stores - our Autozone & Advanced Auto both have them... If there is enough thread exposed on the studd you would be able to double nut it... An easy out - not going to work for this app
It is the large belt tensioner bolt..the 16mm one, I still have the engine jacked up so I have straight on access. The vice grip thing is the first thing I tried with no luck.
I am not sure I can get two nuts on there just because the way the bolt sheared off, I don't think I can get something started on there.
I can't believe the bolt broke as easy as it did.
Not enough threads for using the stud extractor...went and picked one up and no dice....guess I overestimated the amount of thread I had.
I live 2 hours from Mini dealer....should I see if someone local can take the stud out or just take to Mini dealer?
It just stinks because I was so close to being finished.
Anyone have any other ideas?
No stud left to do anything with. Drilling and retap is only option left....I am convinced that easy outs do not and will not in this case work.
Mini dealership is the only one that has touched the car....I don't know the bolt broke so easy in all cases, both with me and the person welding the nut on the stud this morning. Not much effort at all and the bolt just snapped. I would have to say that the bolt is cross-threaded. Don't know, can only try and fix it at this point.
It depends on how messed up the threads are in the hole and the material the hole is in. It is difficult to fix threads in aluminum but steel/iron maybe. Especially if the bolt was cross-threaded into the hole, when you try to tap the threads you might end up with very little thread to accept the torque of the bolt without the bolt just spinning in the hole. For a heli-coil you drill a slightly larger hole and insert the heli-coil which replaces the original threads.
patsum
26
05-29-2021 06:29 PM
