inertia switch/impact switch ???
Does anyone know if this/these exist on a 02 S (May build) and where?
MY MINI won't start , it's definitely 'cause of no fuel flow and it does'nt make sense, car ran great for 300miles, I cleaned it up came back a month later and no start 'cause of no fuel. I'm thinking maybe I tripped the inertia/impact switch when I was wipeing around the MINI which I do thoroughly, under the bonnet, in the boot, door jambs, everywhere. I even got into the little trap door compartments in the boot where the tool kit is.
I'm sure someone with better knowledge that be will chime in, but I don't believe the MINI's employ an inertia switch per se. The approach as I understand in the Mini is that the is conection in the harness that is designed to break apart when the airbags deploy. Effect is the same as an inertia switch but a bit more dramatic and less resetable
Here's the part number: 07 13 1 068 856. It's in the electrical section of http://www.realoem.com/bmw/ or http://www.penskeparts.com/index.aspx. Unfortunately, the diagram is very basic and does not indicate where the part is located on your MINI.
![Mad](https://www.northamericanmotoring.com/forums/images/smilies/mad.gif)
Vendor
On the 02-03 it was located about 8 inches away from the brake master cylinder. Looks just like the pic that Kent posted. In 04 they made the fuel cutoff part of the airbag module.
10-01-2015 12:34 PM
10-01-2015 12:34 PM
10-01-2015 12:28 PM
10-01-2015 12:28 PM
10-01-2015 12:13 PM
