Third oxygen sensor install?
#26
#28
![Grin](https://www.northamericanmotoring.com/forums/images/smilies/grin.gif)
![LOL](https://www.northamericanmotoring.com/forums/images/smilies/lol.gif)
#29
#30
Those damned O2 sensors again!!
Referring back to my initial post last year: finally, I broke down & purchased two Bosch 'OEM' sensors (#13878) and installed them yesterday. I erased all codes (P0130 & P0136 again...). SES light off. Drove around a while: still off. Drove to work & back today: still off. I'm thinking I liked it. Now I can return to get my reject sticker replaced with a real one! Not so fast!
My wife borrowed the MINI tonight & called me no more than 5 minutes after leaving the house. "why's the SES light on? I thought you'd fixed it!".
So, I guess the Bosch OEM 13878 sensors don't work. Unless......there really is something hiding behind the O2 sensor code that only MINI dealer code readers can see. I'll keep y'all up to date on my progress.
#31
I didn't have to reset anything on mine (2003 r50), the light just went off after the install. There's some insight in this thread as to what else might be causing the code. As I mentioned above, I had one Bosch on my car, and looked ancient compared to the other one (and I think it was the cat-forward sensor).
#32
Those oh so famous O2 sensors....
I cleared the two O2 sensor codes again & 10 miles down the road: the SES light is back on again. I don't have time for this cr*p! I have a reject sticker on the MINI right now & really need to get it taken care of. Does anyone out there have 'good' experience with a shop in the Raynham / Taunton MA area that you can recommend? It may just need proper BMW/MINI software to clear the past codes & maybe the history to keep the SES light off.
Help! Please...!?!
Help! Please...!?!
#33
So long as you continue to run the Bosch oxygen sensors, you're going to continue to get the SES code. It does not matter whether you clear the code or the dealer does it. From what I have read in past forum posts, the only OEM reference oxygen sensor that will work is the NTK 25648. Summit Racing has them for $130 each: http://www.summitracing.com/parts/NGK-25648/.
MINI_42 (11-20-2022)
#34
silence2-38554
98
09-21-2016 02:52 PM
squawSkiBum
10-02-2015 09:21 AM
