serpentine belt (R50)
Not sure if this goes here or under the how to section.
But I have read that the mini S's take a MINI tool to release the tension on the serpentine belt tensioner
Have not read anything about the base MINI needing this (I see they have different belts and different paths)
Does anyone know of a good tool or where to buy a base MINI serpentine belt TOOL?
Vendor
Yes there is a tool for the R50, but there is also a 3/8 drive hole in the tensioner so a common belt tool kit, or even a 3/8 breaker bar can commonly get it without buying a tool.
Here is the belt for your car.
http://www.waymotorworks.com/oem-coo...rive-belt.html
Also for you in HI, let me know if you need any parts we have several customers there. We try to ship USPS flat rate to you so you don't get killed on shipping.
We used the tool from the local autozone when we did the belt on the R50 last year. I'd reccomend taking the wheel and liner off and putting the front on jackstands. Actually had to try it a few times because the gap is so small with the liner there, it's a few extra steps but made the work much easier.
To take the tension off the belt I used an insert for a 3/8 drive socket with the 3/8" square on one end, and a 9/16" hex on the other. These are used on sockets when space is tight, and be able to use a wrench to turn the socket. This will fit into the square hole in the tensioner. I used a 9/16 box end wrench on the hex of the insert to take the tension off the belt. To hold the tensioner I used a 3mm hex key. Worked great, and no extra tools to buy.
OEM tool alternative
Hi,
I used an open ended Shimano Hollotech bottom bracket tool to lever the tensioner on my R50. No issues, but it did help to add a 12-inch loop of cord to the handle (rather than a length of pipe) for leverage and control.
http://www.amazon.com/Shimano-TL-FC3.../dp/B000C579LQ
The tool is about $86 in Genuine MINI right now.
http://www.ecstuning.com/Search/SiteSearch/83300493979/
elverado
01-18-2022 02:51 AM
09-10-2015 01:50 PM
09-10-2015 01:48 PM
