Whistling noise coming from under bonnet, YOUR EAR WILL CRINGE PLEASE HELP!
Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
Hey guys, so the past couple of days i've been hearing this distinct whistling sounds when I'm driving. I tried to isolate the problem, thought it might be brakes or something but it's definitely coming from under the bonnet. The car can be idling, in neutral, and when I give it a little gas it produces this whistling sound. I have a video right here, you can hear it very clearly.
Any idea what this could be? I just got the car a month ago I hope its not anything too crazy :(
It's loudest in that area where the camera is pointed. And that was just idling, no depression of the clutch or anything, just consistent engine revs. So I'm guessing the fix is to replace the tensioner?
It is doable, provided you have the belt removal tool. Might be a little tight with some of the bolts if you are a bit ham-fisted. I was able to replace mine without raising the engine ala s/c pulley install, but that might have made it easier, if you consider raising the engine easy.
