Removing the Starter in a 2004 Mini
If the Bentley manual is correct...
-disconnect battery.
-working between engine and engine compartment rear bulkhead, remove exhaust manifold heat shield mounting bolts and lift out heat shield.
-remove exhaust manifold.
-remove starter motor heat shield.
-disconnect wires to starter.
-remove starter mounting bolts and lift out starter.
-installation is reverse of removal.
torques:
-exhaust manifold heat shield to cylinder head - 10 ftlb
-exhaust manifold to cylinder head - 18 ftlb
-starter head shield to engine block - 7 ftlb
-starter to transmission - 63 ftlb
-terminal 30 to starter - 10 ftlb
-terminal 50 to starter - 6 ftlb
torques:
Vendor
If you need a cheap starter we have a couple used ones from some MINI's we are parting out. Be careful with used starters they are different from car to car mainly with different transmissions.
09R56
11-16-2022 10:49 AM
F55/F56 Rear seat back removal anyone?
flyers47
07-27-2020 02:38 PM
Drivetrain Help on MAF Sensor Clip - Cannot Remove
Motown
04-20-2018 09:31 AM
ClayTaylorNC
08-10-2015 09:19 PM
DWooderson
08-10-2015 09:12 AM
