12v socket not working, Fuse?
on
Pages 189 & 190 of the 2008 Owner's Manual (I presume the information should be on or near the same pages of the 2009 manual) cover fuse box locations within the vehicle; one in the engine compartment, and one in the passenger's-side footwell. I would expect that each box has a fuse guide within it, but never having looked inside of mine, I'm not sure how cryptic MINI has made theirs (I know the one GM supplies is not very intuitive).
Bear in mind that, while the 12v outlet is almost certainly on a fuse-protected circuit, often things like this are on the same circuit as other electrical components (e.g., I'd also lose the electric door locks in my 1989 Firebird when the fuse protecting the 12v outlet blew). So, you may have to "cross-reference" the fuse that protects the 12v outlet by looking under the heading of any other electrical component(s) that has/have lost power; it may be a bit of a "goose hunt" to find the offending culprit.
Happened to me as well. The fuse is located in the passenger side footwell. I would pick up a pack of different amp fuses and a fuse puller/tester from your local auto parts store as your Mini has no spares. Mine kept blowing as I tried to plug in a 12V outlet 1 to 3 adapter. The one I had chosen not only had the metal contact at the end but a metal band around the side. This caused a repeated short every time I tried to plug it in. If you want a splitter find one that is all plastic except for the actual contact. According to this link (https://www.northamericanmotoring.co...own-twice.html) the fuse number and amperage is F42 (20 Amp). The tester will confirm this.
fuse box
fuse
07-16-2020 12:54 PM
triple5soul
21
07-29-2016 04:27 AM
minipopkart
08-13-2015 05:22 AM
xraycat
08-12-2015 02:36 PM
nismo4life
08-05-2015 08:31 AM
