The ubiquitous rattle...
Greetings & salutations to all NAM members... I've been lurking for a while, but this is my first post...
I have a '04 S model Mini w/75K miles that although being a wonderful car and a blast to drive, has turned evil on me like a vindictive x-wife...
I noticed a rattle on both sides of the front end when I would run over a bump or irregularity in the pavement... It's a metal-on-metal rattle... It can take place anywhere from 5mph - 45mph... I took it to the local dealer and was presented with an estimate very close to the gross national debt... Motor mounts, control arm bushings, valve cover & oil pan gaskets and alignment... I decided to shop around and found a shop with a lower estimate and had the work done...
They replaced the lower engine mount, upper RF engine mount & tower, #2 front strut mounts, #2 urethane caster bushings and did a 4-wheel alignment on the car... I also replaced all 4 tires... The car has 19 inch alloys with 35 series Continental high speed radials...
The shop's invoice references 'caster' bushings, not 'control arm' bushings... Are these one in the same or not???
While the car does drive much better, it still rattles just as it did before... Actually, the rattle is worse...
What are my next steps??? Sway bar bushings??? Possibly bodywork rattling??? Seppuku???
I chased the rattle in mine for over a year. Out of desperation I went to the dealer & talked with a very good tech. His advice was what I gave to you.
When you pull the pads look closely & you will see shiny parts of the pad backing plate where it is banging on the caliper. The caliper will have matching shiny points.
I finally got around to replacing the front pads my Mini today... I ordered a set of EBC greenstuff pads to replace the oem pads...
The source of the rattle was the metal spring-clips on the inside of the pads that fit into the caliper piston... On the left side, all three spring-clips had broken off and on the right side one had broken off... They were spinning around inside the piston and when I hit a bump, they would rattle... The new EBC pads took care of the mysterious rattle...
I know I am jinxing myself, but my Mini is rattle-free!!!
patsum
06-18-2013 04:34 AM
MINI MI
01-31-2013 08:37 PM
Bponce23
08-21-2012 02:47 PM
Drivetrain custom exhaust build thread part II
soccerbummer1104
05-09-2011 11:53 AM
