2003 R53 OEM Xenon Problems
on
My 2003 R53 w/35k miles has OEM xenons. A few months ago, the passenger side headlight was not igniting. After switching the lights on and off for about a half dozen times, it would finally ignite. This problem kept on getting worse, and from reading the forums, I replaced the ballast and bulb (found used on NAM of course). It worked perfectly for about a week and died again.
I have switched the ballast with the driver side to make sure it is operational, and yes, it works fine.
So far, from my reading, I think it may be the ignitor? I vaguely remember reading this was built into the headlight assembly itself, and you can't really find a replacement.
Is this a valid diagnosis, or could something else be wrong?
Thanks!
Thanks!
You've got to be kidding. I have the exact same prognosis as berger21 except now my driver side is working sporadically.
Anyone know if I can swap the xenon to regular lamps when buying the new headlight cluster?
Is this a problem with all xenons or does it seem to be more of a MINI quirk?
I personally am afraid to get a used assembly as it too may be intermittent so I am living with it for now. But it is annoying to say the least.
///Rich
on
I also asked my dealer to get me a takeout bad assembly so i can see for myself what it would take to repair this. It would be a good business for someone if they get the process right as there are a LOT of bad ones out there.
Rich
Xenon problems
My '03 MCS has had constant problems with getting both headlights to fire up consistently. I'm wondering if a cheaper solution than buying expensive new headlight assemblies might be by gutting, or bypassing the factory electronics, and re-fit with an aftermarket HID kit. At least those parts are reasonably priced and easy to get, if problems present themselves in the future.
Has anyone here tried this ?
Takes around 20 minutes to replace but you will have to move over the washer. Be sure to read the manual carefully as you don't want to break it.
Rich
Here is my story regarding Xenons on my 2003 MCS (115Kmiles at the moment).
Until 50Kmiles, both worked perfectly fine. Due to a debris on the freeway, the front glass was broken on the passenger side, and I had to get a replacement (i.e., the entire assembly). I found one at a local shop for $250 (taken from another MCS). The replacement lasted about 10Kmiles and as the symptoms described by the OP, the problem was the ignitor (switching everything else didn't replicate the problem on the driver's side). Then, I purchased the second replacement on eBay for $175. So far, the 2nd replacement has been working fine.
I understand the concerns about buying a used one, but it doesn't mean that it will definitely have a problem. For instance, my driver's side Xenon is still the original one since 2003 and works just fine.
My suggestion would be to check eBay often until you find a good deal. They seem to be ranging from $250-450.
By the way, keep in mind that repeated on/off cycles to get the faulty ignitor to work will damage and shorten the life of your working Xenon unit. I'd replace it sooner than later, if you have to do this quite a lot...
Good luck!
Good luck!
on
I know this is quite the thread necro but I figured someone would complain if I started my own thread or if I brought this back from the dead. I was having a blast trying to get to the bottom of codes P0301 and P0201 in the middle of the night and dropped one of the intercooler clamps into the engine bay and said after 4 years I was done with this car and wanted an STI. When I shut the hood and fired up the car to see what would happen with a missing intercooler clamp I realized that my driver side headlight would not turn on.
I had to laugh that I spent 4 hours doing what most of you could do in 15 minutes, hurt my back, did not fix my car and now the headlight was out. I didn't really care, I was too cold and tired. Today I called the dealer to order a replacement and was not laughing when he said $220 dollars for a single Xenon replacement bulb. I ended going to my local NAPA and buying the same light and put it in and much to my, what am I saying, not to my surprise it did not work either. So in your guys much more educated opinion, do I need to buy this ballast I am reading about and an ignitor? Are there any other trouble shooting things I can try? Any input would be appreciated.
![](http://i338.photobucket.com/albums/n435/mdbsat_bucket/necro3.jpg)
...my driver side headlight would not turn on....I ended going to my local NAPA and buying the same light and put it in and much to my, what am I saying, not to my surprise it did not work either. So in your guys much more educated opinion, do I need to buy this ballast I am reading about and an ignitor? Are there any other trouble shooting things I can try? Any input would be appreciated.
If it turns out you need the ballast, PM me as I have one and can get it to you cheaper than elsewhere. But my bet is that is not the problem.
Rich
'03 R53 Xenon problems
I finally fixed (most of)my lighting problems. I bought two new light assemblies for $500 after shipping on eBay. They did not come with ballasts, so I used the old ones. I did get two new Phillips Xenon bulbs for another $75 on eBay. Everything seemed to work fine, they both lit up first try, but one (R) still would flicker and go out. So, I ordered 1 used ballast on eBay for $125, and now everything works great, except no high beam on the right. It did this with the old lights too. I've tried swapping bulbs side to side, same result.
Is there a dedicated fuse for each high beam ?
on
If you move the ballast from side to side (they are the same) you can tell if you have a bad ballast. Most likely that is not the problem and it is the igniter which is internal to the lamp assembly and not replaceable. The new assembly is expensive. You may be able to find a direct replacement Hella 010071031 for a bit less. You could have tested the bulb, BTW, by moving that as well but that is water under the bridge.
Rich
Rich
The guy at the dealership said that they dont sell the whole headlight assembly and that he had a "Control Unit." Is this is a ballast? He gave me a part number of 63127167068. I may take you up on the offer of the ballast, I just need to figure out what one is first. I am at work so I will research more when I get home. I really appreciate the reply. I am just at my wits end at this point and having the headlight go out after hours of working on another part of the car was just too much
![Mad](https://www.northamericanmotoring.com/forums/images/smilies/mad.gif)
...I don't really know what I am doing...I just got off the phone with the dealership to buy a new headlight assembly and be done with it....The guy at the dealership said that they dont sell the whole headlight assembly and that he had a "Control Unit." Is this is a ballast? He gave me a part number of 63127167068....I may take you up on the offer of the ballast, I just need to figure out what one is first. I am at work so I will research more when I get home. I really appreciate the reply. I am just at my wits end at this point and having the headlight go out after hours of working on another part of the car was just too much![Mad](https://www.northamericanmotoring.com/forums/images/smilies/mad.gif)
Again, I doubt that is the problem so be sure first as the OEM price for that unit is $400 and since it is electronic, most dealers won't take it back if that is not the problem. So going to that dealer would be an expensive mistake if the control unit is not the problem. Most times it is the igniter that is internal and not replaceable except with the whole unit part number 63126933839 for over $600. Here is the link to the parts pictures. Again, switch the control unit side to side. It will only take 15 minutes and you'll know.
Rich
PS-BTW-I love my 2003 MCS. Yes, it has quirks but when I hit the twisties, everything is right with the world.
on
The control unit is the silver box that hangs on the bottom of the assembly. The left and right ones are the same so if you switch them side to side and the problem moves then the unit is bad. And that is what I have if you find you need it.
Rich
Rich
I have enjoyed my Mini and still do but too much has happened in too short a time for me. I am going to try to switch the control unit when I get home in a few minutes. I just want to make sure I am switching the correct thing. So I will be switching part #1 on the link you sent. The one called control unit correct? I am trying to find a little DIY on the net but it is probably too simple for most people. I just dont want to end up with no headlights at all and at this point I could see that happening
![Sly](https://www.northamericanmotoring.com/forums/images/smilies/sly.gif)
Thanks for your help Rich. If I switch them and it is that part I will PM you and buy whatever replacement you have. Thanks again
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
on
I just finished. It looks like I wasted $100 on a bulb as it was the ballast after all. I cannot believe the dealership wants $400 plus for that part. Especially a part that using google one can see is in high demand due to so many of them failing. I saw a used one on fleabay for $133 dollars. Is this the part you have for sale Rich? I am just confused about what is what. I will PM you, and thanks for your help.
Rich
Anyone know if the Hella Projectors would fit an '03? Or whether Hella Reflectors have ignition devices that are separate from the assembly? Unlike the OEMs. I've got the Xenon issue on mine and I'm debating what to do. I was under the impression that other than the fact that the pre-facelift was a reflector and the post-facelift was a projector that physically the lights would fit in the car exactly the same. However, if you go to Amazon, or any of the auto-parts stores that stock the Hellas, they indicate that the projector versions do not fit anything pre-2005. Perhaps the retailers saying they don't fit is just a nonsensical requirement?
08-12-2015 01:24 PM
