Am I in trouble or is this normal?
I have been out and about today running errands. Twice after driving I shut the engine off and the cooling fan kicks on and runs for a few minutes. I don't think the car was overheating either time but it did look like some coolant did come out of the cap. I know the cooling system should not leak so that makes me think something might be up. Is the fan running after shut down normal, or is this a sign that something is amiss?
Was the fan really really LOUD ?
BTW: Dash temp gauge next to the gas gauge is worthless....it will only read hot when it's too late and a new head has to be purchased. Do yourself a favor and get a Scanguage II and use that to monitor your engines vitals.....
I am almost positive it was the radiator fan moving air through the radiator. The coolant also looks like it might be slightly on the low side.
The coolant overflow tank should be around 1/3 to 1/2 full. Does not mean you are low on fluid. What year and how many miles do you have.
Fan has two speeds......low and high....You are not supposed to ever hear the high speed fan running unless you are having issues......
That is why I asked if the fan you heard was REALY REALY LOUD.....if so, that is the high speed fan in a last ditch effort in keeping your engine cool. Your last line of defense from having to buy a new engine.....
So could be the low speed fan is kaput.
Before everyone gets you all worried and spreads the worst around like all forums do. What color was the fluid? 9/10 its just condensation from the a/c. Remember blue for washer fluid, greenish yellow for coolant/antifreeze, red normally for auto tranny fluid, black for oil, and amber for brake fluid.
cap = condensation......in summer time ? I dont get it.
Getting folks "all worried here like all other forums do ? " Meaning what exactly....You must be new here friend......
I am living in louisiana and the temp has been hovering around 100. The temp gauge is around midway when running.
So gRey hot do I differentiate between the low vs high speeds. If I had to describe it I would say it sounds like the same loudness when the car is running.
The low speed fan is almost not even heard over the engine running. You should not be able to hear the low speed fan at idle much or while at the drive up window of a restaurant.
The high speed fan is quite loud, like a shop vac.....very very noticible difference between the two.
When the low speed fan resistor was fried in my fan assembly, I had to run with the A/C on to over ride the resistor to keep from over heating.
Low speed fan should kick on when temps reach between 215*- 220* degrees. If you see temps reaching 225 to 230* the low speed fan is most likely not working....and a good time to check.
Vendor
Check to make sure the coolant it low, if it is pressure test the system. Thermostats are common to leak, and coolant expansion tanks are common to fail and leak at the seam.
If that is all ok, the radiator fans are known for going bad too, they most commonly fail where they stay on after you shut off the car, or the low speed on them fails.
Way's advice is definitely good to follow if you think there is a problem. And it was mentioned earlier in the thread, i believe, that the temperature gauge on the dash doesn't accurately display temperature after operating temperature is reached. If you want to more accurately monitor your temperatures, consider a Scanguage II. It can be set up to display most pertinent information that the ECU already monitors. Including coolant temp.
How would one know when a new head is needed? What will one see/hear/feel, besides the gauge?
I would certainly not be considering what the symptoms of a failure in the head would look like.
if I had seen that guage in the upper half of it's range then I'd start being a bit more concerned.
Tires, Wheels & Brakes
09-16-2015 06:45 AM
09-16-2015 06:44 AM
